Flexible Waterproof LED Strip - White
  • Flexible Waterproof LED Strip - White
SKU 104990072
This product is retired, please consider our Flexible Waterproof LED Strip - RGB as your alternative choice
$15.90
DISCONTINUED
This product is retired, please consider our Flexible Waterproof LED Strip - RGB as your alternative choice.
Looking for gorgeous LED strips to add some fun to your project? Try to find something you want here !
The LED strip Uses trinity-SMD LED as lighting source, with low voltage with resistance and  IC constant current made the shining stable, bright and uniform.  FPC circuit board made it easily to bend, Besides, self adhesive back makes it convenient to stick them to any flat surface.
These LED strips are sold by roll, each roll of 5 meters long and comes with connectors. Other color LED strips are also available for you to choose: Red, Yellow, Blue, Green, White and RGB.
  • 10.0mm wide, 3.2mm thick, 50mm long per segment (3 LEDs).0.24w per LED.
  • Clear waterproof molded (IP65)
  • Maximum 12V per strip segment
  • Max 1.2 Amps per meter (all LEDs lit full brightness)
  • 3 common-anode LEDs per segment, 20 segments per meter
  • No microcontroller or chip controller ('analog' only!)
  • Controller is  Not Required
See More
$50 Featured List
$100 Featured List
$200 Featured List
Don’t miss out!
Questions and Answers
SUBMIT
0
what size is the led filament? is it a 5050 or a 3528 size?
on Oct 19,2016
Replyupvote ()
5050 size
on Oct 20,2016 10:47 AM
Replyupvote ()
Reply
0
is the flexistrip sold by the meter or by the roll of 5M ?
GZ
on Oct 19,2016
Replyupvote ()
HiGZ.you can purchase it by meter.
on Oct 20,2016 10:45 AM
Replyupvote ()
Reply
See More
Recommended Products
Grove - ButtonGrove - Button
$1.9
ADD TO CART
Grove - I2C Touch SensorGrove - I2C Touch Sensor
$16.9
ADD TO CART
Grove - Thumb JoystickGrove - Thumb Joystick
$5.9
ADD TO CART
Grove - Button(P)Grove - Button(P)
$1.9
ADD TO CART
Grove - Switch(P)Grove - Switch(P)
$2.9
ADD TO CART
Grove - EncoderGrove - Encoder
$4.9
ADD TO CART
Readiymate PT3-D1Readiymate PT3-D1
$19
ADD TO CART
View History
Best-sellers
SUBMIT
Invalid email address.
