Flow Breakout Board
Flow Breakout Board
SKU 114991252
40.00
50+ Available
$40.00/ 1pcs+
The Flow breakout board is used for motion tracking and can easily be connected to any robotics project or other design.
The motion of a surface, usually the ground, is measured and is reported as delta X and delta Y by the optical flow sensor. The absolute distance (Z) is measured by the Time of Flight ranging sensor. It comes with an Arduino library to easily read the movement data and has a large voltage range for IO and power supply.
The Flow breakout features the VL53L0x ToF sensor and the PMW3901 optical flow sensor.
  • Fast, accurate distance ranging
  • Measures absolute range up to 2m
  • Measures movement in X/Y using optical sensor
  • Power supply and IO 3V - 5V compatible
  • Arduino library for easy usage
  • Minimum range for motion tracking is 80mm
Compatibility
  • Compatible with 3 to 5V system
  • Optical flow requires an SPI port
  • ToF ranger requires an I2C port
Technical Details
Dimensions20mm x 26mm x 4mm
WeightG.W 3.50g     N.W 2.70g
BatteryExclude
VCC 3V to 5V
VL53L0x ToF sensor (I2C)
PMW3901 optical flow sensor (SPI)
Two M2 mounting holes
Flow breakout1
10 pins male header1
ECCNNot Available
HSCODE9503009000
Reviews
Questions and Answers
SUBMIT
    View History
    Flow Breakout Board
    SKU 114991252
    $40.00
    50+ Available
    $40.00/ 1pcs+
    • Related
    • Description
    • Technical Details
    • Learn
    • Reviews
    • Questions and Answers
    SUBMIT
