Flow switch--MR-W1-P
SKU 311990002
12.99
DISCONTINUED
This sensor works as a switch, conducts while flow pass though.
Specifications
  • Max switch current: 0.5 A
  • Max load current : 1.0 A
  • Max resistance: 100 ohm
  • Max load power: 10 w
  • Max switch voltage: 100 vdc
  • Min damage voltage: 220 vdc
  • Min sensible flow: ≥0.1L/MIN
  • Working flow range: 1-30L/MIN
  • Min sensible pressure: ≥0.1 mpa
  • Min water pressure: 0. 1 mpa
  • Max water pressure: 1.2 mpa
  • Working temperature: 1-80°C
  • Storage temperature: -20-10°C
  • Life: >108 times
  • Response time : 0.2 sec
  • Release time : 0.2 sec
Documents
Technical Details
Dimensions100mm x 80mm x 26.50mm
WeightG.W 27g
BatteryExclude
ECCNNot Available
HSCODE9026100000
Reviews
Questions and Answers
SUBMIT
    View History
    SKU 311990002
    $12.99
    DISCONTINUED
    $12.99/ 1pcs+
    • Description
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
