Frog:bit Gamepad for Micro:bit & Meowbit
Joyfrog is a programmable interactive gamepad that can be programmed with Makecode Scratch. It's easy to use and can be connected to micro:bit as a gamepad expansion board. It can also be used independently as a programming board through Kittenblock scratch programming software.
$39.90
In stock
  • 2+: $35.90
  • 50+: $31.90
 Joyfrog A01
Joyfrog is able to be recognized as a HID input device automatically when it is plugged into the computer. It eliminates the need to manually install the driver and can be used as part of the keyboard input button without opening any programming software. Joyfrog controls the movements of the stage character through the programmable joystick and the buttons of it.
 Joyfrog A02
The Joyfrog can be used as a music module for Scratch. After connecting the connecting finger contacts to several fruits through the alligator clip, we can easily make a fruit instrument. Scratch's music module has 18 percussion instruments, for students to imagine what is possible.
 Joyfrog A03
In addition, the frog handle has two PH2.0 3pin connectors, which can be connected to the conventional 3pin sensor on the market. There are two PH2.0 4PIN interfaces, you can insert the PowerBrick modules of Kittenbot to make the DIY projects more abundant.
The on board infrared emitter/receiver has built-in automatic infrared decoding NEC. You can decode the conventional remote control on the market and return the decoded data to Kittenblock. You can also record it and then programmatically send different IR codes so that you can control the infrared devices in your home as well as 2.4G infrared wireless toy cars/robots.
 Programming Board
Onboard 3PIN connector and 4PIN connector for interacting with the stage of Kittenblock through a variety of common sensors
 Act as a Gamepad
Control the stage character directly as a Gamepad in Kittenblock; Act as a Gamepad, remote control robot cars or robots (2.4G infrared wireless)
 Fruit piano function
Simulates up to a dozen instruments combine with the music plug-in
 Infrared remote control
Easy to control infrared devices in your home(such as TVs, projectors, etc.)
Joyfrog A01
1. Infrared receiver
2. Audio interface
3. Audio / buzzer switch
4. Reset button
5. DFU mode button
6. 4P module interface
7. Joystick
8. connecting finger contacts (1~8, GND)
9. Microbit 40PIN horizontal interface
10. Main chip
11. Buzzer
12. Button (X, Y, A, B)
13. 4P I2C interface
14. Micor USB connector
15. Infrared emitter
16, 17. 3P module interface
 Size
128mmx80mmx35mm
 Main Controller
GD32F350C8T6, flash64kb, SRAM8kb, 108MHZ
 Onboard programming resources
Two-axis joystick, four buttons, infrared emitter/receiver, 8 connecting finger contacts for alligator clips, buzzer, audio/buzzer switch
Interfaces
Micro:bit 40pin horizontal connector x 1, GVAB 4pin PH2.0 x 2, GVS 3pin PH2.0 x 2, 3.5 audio Jack x 1, standard NRF24L01 8pin 2.4G wireless interface x 1
 Supported programming environment
Kittenblock, Makecode
 Input voltage
5V
 Power supply port
micro USB
Joyfrog gamepad board x 1
Battery holder x1
Micro USB Cable x 1
silicon case for gamepad board x 1
HSCODE 8543709990
UPC
Product Faqs
Sort by
  • Hi, Is there any documentation for it in English ? Translation doesn't translate text in images in current documentation
    Question by: Nadeem Shahbaz on 2019-09-16 01:14:21
    Hi there~ We will release the English user guide by mid of Oct. thanks.
    Answer by: admin on 2019-09-17 06:16:44
Bundle Sales
