Fusion PCB Service - 4 Layers
  • Fusion PCB Service - 4 Layers
SKU PCB02281P
  • About Fusion PCB service:
  • As hobbyists ourselves, we organize local manufacturing power, reduce the shipping cost, and ensure the quality
    $39.90
    OUT OF STOCK
    This item is not available at the moment
    Get notified when it's back in stock
    As hobbyists ourselves, we organize local manufacturing power, reduce the shipping cost, and ensure the quality. It will be a source to sustain our company along with other services we provide.
    1.NEW Fusion PCB Order Steps:
    • Upload your design file (One file, one order!).
    • Filling in the PCB parameters according to your file.
    • Press “ADD TO CART” button to submit your purchase.
    If design files meet the requirements, PCBs will be manufactured and shipped in 5-7 days (excluding the Chinese Festivals).
    2. Fusion PCB capabilities:
    Multi Layers1-4
    PCB MaterialFR-4
    Available ColorGreen, Red, Yellow, Blue, White, Black
    Silk Screen ColorWhite, Black (For White Solder Mask only)
    Minimum Quantity10
    Maximum dimensions*5cm X 5cm
    5cm X 10cm
    5cm X 15cm
    5cm X 20cm
    10cm X 10cm
    10cm X 15cm
    10cm X 20cm
    15cm X 15cm
    15cm X 20cm
    20cm X 20cm
    *PCB design must be in the length range (not area) of the dimensions you selected.
    Manufacturer Specifications
    3. Gerber files requirements:
       The following layers are needed:
    • Top Layer: pcbname.GTL
    • Inner Layer: pcbname.GL2
    • Inner Layer: pcbname.GL3
    • Bottom Layer: pcbname.GBL
    • Solder Mask Top: pcbname.GTS
    • Solder Mask Bottom: pcbname.GBS
    • Silk Top: pcbname.GTO
    • Silk Bottom: pcbname.GBO
    • Drill Drawing: pcbname.TXT
    • Board Outline:pcbname.GML/GKO
      Note:
    • The Gerber file must be RS-274x format.
    • Fusion PCB do not support blind/burried vias.
    4. PCB design tips:
    • One Gerber file, one design.
    • Drills line and long slot cannot be accepted.
    • Minimum slot 1mm*2mm.
    • DRC compatible as rule file attached.
    • Please try to make your PCB width larger than 20mm to reduce manufacturing cost.
    • PCB design must be in the length range (not area) of the dimensions you selected.
    5. Panelizing
       For the following services, you can panelize to save the cost, but you need to cut the board by yourself.
       5cm Max * 5cm Max
       5cm Max * 10cm Max
       5cm Max * 15cm Max
       10cm Max * 10cm Max
       10cm Max * 15cm Max
     The rules of Panelizing:
    • There should be no more than 5 sub-boards to fit the size.
    • The sub-boards should only be separated by the silkscreen. Using any holes or slots to separate the sub-boards is not permitted.
    Note:
    Cadsoft Eagle 4-layer Gerber Generator (Copper layer need in 1, 2, 15, 16)
    Price for Fusion PCB Service - 4 layers
    See More
    $50 Featured List
    $100 Featured List
    $200 Featured List
    Don’t miss out!
    Questions and Answers
    SUBMIT
    0
    Hello,
    Can you tell me what the your minimum annular ring is?
    on Oct 19,2016
    Replyupvote ()
    See More
    Recommended Products
    Fusion PCBFusion PCB
    $0
    ADD TO CART
    PCB Stencil ServicePCB Stencil Service
    $0
    ADD TO CART
    Fusion PCBAFusion PCBA
    $10
    ADD TO CART
    View History
    Best-sellers
    SUBMIT
    Invalid email address.
