seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      G5&4" Water Flow Sensor
      SKU 314150004
      $29.50
      DISCONTINUED
      Water flow sensor consists of a plastic valve body, a water rotor, and a hall-effect sensor. When water flows through the rotor, rotor rolls. Its speed changes with different rate of flow. The hall-effect sensor outputs the corresponding pulse signal. This one is suitable to detect flow in water dispenser or coffee machine.
      We have a comprehensive line of water flow sensors in different diameters. Check them out to find the one that meets your need most.
      • Compact, Easy to Install
      • High Sealing Performance
      • High Quality Hall Effect Sensor
      • RoHS Compliant
      Specifications
      • Dimension: 120*55*51mm(thickness), DN32(Outside: 42.4mm, inside:32mm)
      • Mini. Wokring Voltage: DC 4.5V
      • Max. Working Current: 15mA (DC 5V)
      • Working Voltage: DC 5V~24V
      • Flow Rate Range: 0~120L/min
      • Load Capacity: ≤10mA (DC 5V)
      • Operating Temperature: ≤80℃
      • Liquid Temperature: ≤120℃
      • Operating Humidity: 35%~90%RH
      • Water Pressure: ≤2.0MPa
      • Storage Temperature: -25~+ 80℃
      • Storage Humidity: 25%~95%RH
      Documentations
      Technical Details
      Dimensions130mm x 70mm x 50mm
      WeightG.W 203g
      BatteryExclude
      G5&4"Water Flow Sensor1
      Reviews
      View History
      SKU 314150004
      $29.50
      DISCONTINUED
      $29.50/1pcs+
      $26.55/10pcs+
      $25.07/20pcs+
      $23.60/50pcs+
      • Best-sellers
      • Description
      • Technical Details
      • Learn
      • Reviews
      • Questions and Answers
      • View History
      SUBMIT
      Invalid email address.
