seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Galvanometer motor (SC17-15K)
      SKU 316010012
      $69.95
      OUT OF STOCK
      This item is not available at the moment
      Get notified when it's back in stock
      Galvanometer motor is a lower cost stander parts used in laser equipment, easy to be used and assembled. it's offer a most cheap, convenient option when you want to controll the light beam
      Feature
      • Small volume
      • compact structure
      • convenient installation
      • Analog signal control
      • Scanning Angle: ±30 ( ±20)
      • Rotor inertia:  0.025 gm*cm2, ±10%
      • torque:  2.5 x 104 dyne-cm/amp, ±10%
      • The maximum coil temperature:  100℃
      • The stator coil shell heat resistance:  8℃/W
      • coil resistance:  8.3Ω±10%
      • coil inductance:  153uH±10%
      • The average current carrying:  1.5A
      • response time one step:  0.3ms
      • linearity:  99.0%
      • Repeat accuracy:  15 microradians
      • Size of the lens:  7mm*11mm*0.6mm
      • Mirror reflectivity:  >98% @45° ( 380nm-700nm)
      For any technical support or suggestion, please kindly go to our forum.
      Technical Details
      Dimensions145mm x 110mm x 52mm
      WeightG.W 319g
      BatteryExclude
      Galvanometer motor (SC17-15K)1
      Reviews
      Questions and Answers
      SUBMIT
      0
      Can you supply the wiring diagram/ data sheet of the galvanometer to the products technical details, or by email?
      on Aug 03,2017
      Replyupvote ()
      Hi there~ We have upload the files, please check the Documents. Regards
      on Apr 24,2018 10:07 AM
      Replyupvote ()
      Reply
      0
      What is the Kpps ( kilo point per second ) for this galvanometer at minimum and maximum scanning angle?
      on May 15,2018
      Replyupvote ()
      Hi there~ max angle 20°--15Kpps, we do not have the data of min angle. Regards
      on May 17,2018 14:46 PM
      Replyupvote ()
      i can use this in Laser marking machine ?
      on May 27,2018 20:45 PM
      Replyupvote ()
      Reply
      1
      I would like to know if the power supply and the control board are included with the galvanometrer motors.
      on Mar 13,2017
      Replyupvote ()
      Hi there~ The power supply and the driver board is included, however, you need to buy the control board separately to control the images.
      on Apr 23,2018 15:14 PM
      Replyupvote ()
      Reply
      0
      can this be controlled by g code
      on Apr 20,2018
      Replyupvote ()
      Hi Alex~ Unfortunately, this motor do not support g code. Regards
      on Apr 23,2018 15:11 PM
      Replyupvote ()
      Reply
        View History
        SKU 316010012
        $69.95
        OUT OF STOCK
        $69.95/1pcs+
        $62.95/10pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
