Grove - Ultrasonic Ranger
SKU 101020010
3.90
48 Available
$3.90/ 1pcs+
This Grove-ultrasonic sensor is a non-contact distance measurement module which is compatible with the Grove system. It's designed for easy modular project usage with industrial performance. There is also the electronic version of this module here
  • Detecting range: 3cm-350cm,best in 30 degree angle.
  • Grove interface
  • 5V DC power supply
  • Arduino library ready
Technical Details
Dimensions50mm x 25mm x 16mm
WeightG.W 17g
BatteryExclude
Measuring range 3cm - 350cm
Operating voltage DC 3.2~5.2V
Operating current 8mA
Ultrasonic frequency 40kHz
Connector Grove x1
Output PWM
Grove - Ultrasonic Ranger1
ECCNEAR99
HSCODE9031900090
Reviews
Questions and Answers
SUBMIT
3
Hi ! I need a sensor that can read the blue or red line on the PC screen about 1.5 mm wide on the black bottom, and then give the contact get to start a clock. Which sensor can fit this and I need some additional equipment. Thanks for reply. roald
on Jul 04,2017
Reply upvote ()
Hi~we do have color sensor.But 1.5mm is too narrow to distinguish.So you may need some more complex and precise equipment which we do not have.
on Sep 11,2017 13:08 PM
Reply upvote ()
Reply
1
I want to use three Ultrasonic sensors, one for calibration and two for distance. All your examples show only one in use at D7 using the Grove board. First can I use more than one and what channels on the Grove base board.
on Nov 25,2016
Reply upvote ()
Hi~Of course you can.You can use D6,D7,D8 or any other digital port to plug the Ultrasonic sensor. and I have tested it and write a code to meet your needs.You can email techsupport@seeed.cc ~So that I can offer you the code.
on Sep 11,2017 15:58 PM
Reply upvote ()
Reply
0
Will this work with chipKIT uC32 and LabView ?
on Nov 03,2016
Reply upvote ()
We only provide the library of Arduino and raspberry.I am afraid that it will not work with uC32.
on Sep 11,2017 17:05 PM
Reply upvote ()
Reply
0
Hello, can i connect this module to the Xbee carrier ? Thx
on Nov 01,2016
Reply upvote ()
We only provide the library of Arduino and raspberry.You need to write the library yourself.
on Sep 11,2017 17:06 PM
Reply upvote ()
Reply
0
Hello,I'm looking for "ultrasonic" reference page I would like to know the difference between "ultrasonic.MeasureInCentimeters" and "ultrasonic.RangeInCentimeters".Does anyone know it?
on Oct 19,2016
Reply upvote ()
MeasureInCentimeters : The measured distance from the range 0 to 400 Centimeters. MeasureInInches: The measured distance from the range 0 to 157 Inches. Hope that would be helpful to you.
on Oct 20,2016 10:48 AM
Reply upvote ()
1
on Nov 09,2017 19:33 PM
Reply upvote ()
1
Reply upvote ()
Reply
0
Hi, Can I Integrate this with TI's CC3220SF or any other TI devices?
on Sep 19,2018
Reply upvote ()
Hi there, The sensor working voltage is from 3.3v~5V. if the CC3220SF working voltage is within range, we can use the it from hardware point of view. For the software, We only provide the library of Arduino and raspberry.You need to write the library yourself. thanks.
on Sep 20,2018 16:14 PM
Reply upvote ()
Reply
0
on Jul 04,2018
Reply upvote ()
Hi there, The sensor working voltage is from 3.3v~5V. if the uc32 working voltage is within range, we can use the it from hardware point of view. For the software, We only provide the library of Arduino and raspberry. We do not test the labview before. thanks.
on Sep 20,2018 16:15 PM
Reply upvote ()
Reply
0
Is it possible to have a sample of this device?
on May 10,2018
Reply upvote ()
Hi there~ Could you please tell us what do you want to do with this product? Thanks
on May 11,2018 10:15 AM
Reply upvote ()
Reply
0
Hi - purchased this and tried to run the example project "All in one" with Raspberry Pi. However the sensor does not seem to be able to detect any changes in distance. Also tried to run the "GroveUltrasonicSensor" project and the result was "Distance: 517 cm" on the screen. Couldn't find much documentation online regarding troubleshooting so hoping to get some help from here. Thanks in advance!
on Jun 25,2017
Reply upvote ()
Hi~I am pretty sure that the demo we offered is OK.Could you please check again and see if there are any missing. Here is the link http://wiki.seeed.cc/Grove-Ultrasonic_Ranger/#with-raspberry-pi .After try again,if it still can not measure,you can contact us and then we can talk about refound or exchange.Thanks
on Sep 13,2017 15:51 PM
Reply upvote ()
Reply
0
base on the wiki:Operating voltage: 3.3/5.0VDCOperating current: 15mAUltrasonic frequency: 42kHzSo this one should work on 3.3v system, like Arduino duo, seeeduino arch, right?
on Oct 19,2016
Reply upvote ()
Yes, you can. You can send your design files in one e-mail and name the files like this: order37218_5cm*5cm_1, order37218_5cm*5cm_2, order37218_10cm*10cm_1, and order37218_10cm*10cm_2.
on Oct 20,2016 10:41 AM
Reply upvote ()
Reply
    View History
    SKU 101020010
    $3.90
    48 Available
    $3.90/ 1pcs+
    • Related
    • Description
    • Technical Details
    • Learn
    • Reviews
    • Questions and Answers
    SUBMIT
