seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Grove - I2C Mini Motor Driver
      SKU 105020010
      $10.90
      7 Available
      $10.90/1pcs+
      $10.50/10pcs+
      $10.00/20pcs+
      $9.50/50pcs+
      ADD TO CART
      The Grove – Mini I2C motor driver is a very tiny motor driver with I2C interface, and it includes two motor driver chips - DRV8830, which helps you control two DC motors or winding of stepper motors on a small board simultaneously.
      With four solderable pads back of the board, you can change the I2C address of each motor driver easily. Especially, with the onboard protection circuit, the max limitation current of each channel can be adjusted from 0.2A to 1A, you can set a proper limitation current according to the load.
      It can be used for battery-powered toys, printers, and other low-voltage or battery-powered motion control applications due to the features.
      Also, Grove – Mini I2C motor driver is belong to Grove System, you can plug it onto the Base shield and work with Arduino directly without any jumper wires.
      Features:
      • Tiny driver board
      • Two motor driver channels
      • Working Voltage : 2.75v – 6.8v
      • Changeable max limitation current
      • Grove compatible
      • I2C interface
      • Easy to use
      Please visit our wiki page for more info about this product. It will be appreciated if you can help us improve the documents, add more demo code or tutorials. For technical support, please post your questions to our forum
      Technical Details
      Dimensions130mm x 90mm x 10.5mm
      WeightG.W 9g
      BatteryExclude
      Reviews
      Questions and Answers
      SUBMIT
        View History
        SKU 105020010
        $10.90
        7 Available
        ADD TO CART
        $10.90/1pcs+
        $10.50/10pcs+
        $10.00/20pcs+
        $9.50/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
