seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Grove – Chainable RGB Led V2.0
      SKU 104020048
      $5.99
      50+ Available
      $5.99/1pcs+
      $5.65/10pcs+
      $5.35/20pcs+
      $4.95/50pcs+
        I accept the restriction
      This development board can be only used for prototyping, it cannot be built into a product for commercial distribution. It cannot be re-sold or used as part of a production environment.
      Maximum Qty: 5
      RGB LED always bring us vivid and magic light effect, especially when there are a large number of LEDs shining together. However it is not easy to connect all the LEDs together if you want to build such LED projects. Why not have a try with Seeed’s Grove- Chainable RGB LED V2.0.
      Grove-Chainable RGB LED V2.0 is based on P9813S14 chip. This chip is a full-color light source driver chip that can provide three constant current driver and 256 greyscale modulation output. The key word of this product is “Chainable”, so how many LEDs can it be chained? By connecting the output grove connector of one LED to the input grove connector of another one, you are able to chain 1024 RGB LEDs at most!
      If you have experience using Grove-Chainable RGB LED V1.0, you will find that V2.0 is a bit longer than V1.0. In V2.0, because we adjust the grove connectors to be parallel with the board instead of vertical, so that the cable don’t need to be crooked.
      Technical Details
      Dimensions40mm x 20mm x 15mm
      WeightG.W 11g
      BatteryExclude
      Input voltage5V
      Working temperature-40 – 85℃
      Max working current60mA
      Max Chained LED Quantity:1024
      Grove – Chainable RGB Led V2.01
      Grove Cable1
      Reviews
      View History
      SKU 104020048
      $5.99
      50+ Available
      Maximum Qty: 5
      $5.99/1pcs+
      $5.65/10pcs+
      $5.35/20pcs+
      $4.95/50pcs+
      • Best-sellers
      • Description
      • Technical Details
      • Learn
      • Reviews
      • Questions and Answers
      • Related
      • View History
      SUBMIT
      Invalid email address.
