seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Grove - Sunlight Sensor
      SKU 101020089
      $9.90
      11 Available
      $9.90/1pcs+
      $8.91/10pcs+
      $8.41/20pcs+
      $7.92/50pcs+
        I accept the restriction
      This development board can be only used for prototyping, it cannot be built into a product for commercial distribution. It cannot be re-sold or used as part of a production environment.
      Maximum Qty: 5
      Summer is coming, want to make a UV detector to know the UV index when you are under the sun? Grove - Sunlight Sensor is recommend here.
      Grove - Sunlight Sensor is a multi-channel digital light sensor, which has the ability to detect UV-light, visible light and infrared light.
      This device is based on SI1145, a new sensor from SiLabs. The Si1145 is a low-power, reflectance-based, infrared proximity, UV index and ambient light sensor with I2C digital interface and programmable-event interrupt output. This device offers excellent performance under a wide dynamic range and a variety of light sources including direct sunlight.
      Grove - Sunlight Sensor include an on-bard Grove connector, which help you to connect it your Arduino easily. You can use this device for making some project which need to detect the light, such as a simple UV detector.
      • Digital light sensor
      • Wide spectrum detection range
      • Programmable configuration
      • 3.3/5V Supply
      • Detect sunlight directly
      • Grove compatible
      • I2C Interface(7-bit)
      Technical Details
      Dimensions140mm x 85mm x 11mm
      WeightG.W 6g
      BatteryExclude
      Operating Voltage3.0-5.5V
      Working current3.5mA
      Wave length280-950nm
      Operating Temperature-45-85oC
      Grove - Sunlight Sensor1
      Grove Cable1
      Reviews
      Questions and Answers
      SUBMIT
      0
      can I hookup, 2-3 together on the same seeedstudio V4.2 with expansion board and still get IR, Vis, UV reading out to the ide?
      on Dec 14,2016
      Replyupvote ()
      Hello, yes you can.You need a software I2C because you can't connect 3 modules in one I2C bus.About software I2C please refer to https://github.com/loovee/Arduino_SoftI2C
      on Jan 16,2018 10:09 AM
      Replyupvote ()
      Reply
      0
      Hello! kindly tell me how much maximum lux that we can measure using this sensor module?
      on Nov 30,2016
      Replyupvote ()
      It can measures up to 128 klx (direct sunlight). Please refer the following datasheet https://github.com/SeeedDocument/Grove-Sunlight_Sensor/raw/master/res/Si1145-46-47.pdf
      on Jan 16,2018 10:10 AM
      Replyupvote ()
      Replyupvote ()
      Reply
      0
      is this compatible with arduino uno?2nd question what is the meaning of "operting temperature" does it work only on the said temperatures?
      on Oct 10,2017
      Replyupvote ()
      1.YES ! It is compatible with UNO2.YES !
      on Jan 16,2018 10:15 AM
      Replyupvote ()
      Replyupvote ()
      Reply
        View History
        SKU 101020089
        $9.90
        11 Available
        Maximum Qty: 5
        $9.90/1pcs+
        $8.91/10pcs+
        $8.41/20pcs+
        $7.92/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Learn
        • Reviews
        • Questions and Answers
        • Related
        • View History
        SUBMIT
        Invalid email address.
