the AI Hardware Partner
Toggle Nav
Loading...
Grove - ADK Dash Kit
Refined from Official ADK board design Modular Plug and play Unified 4pin wire with polarized connectors
$59.00
Out of stock
This product is retired, please consider our IOIO OTG for Android as your alternative choice.
Grove - ADK Dash kit provides modular solution for easiest google ADK development. It boosts Android devices with most mind-blowing functions like RFID, Range Finder, Servo, Relay, Temperature and humidity, Thumb Joystick, Chain-able RGB LEDs and all accessories. Dash to Android gadgets development with this kit and an ADK compatible device!
Note: Seeeduino ADK Main Board supports Android devices v1.5 using MicroBridge and v2.3.4 and above with Google Open Accessories API (ADK).
  • Refined from Official ADK board design
  • Modular Plug and play
  • Unified 4pin wire with polarized connectors
  • Standardized form factor for easy mounting and encasing
  • Native Servo hub
  • Supports complex communications like Uart/I2C
  • Supports 3rd party Shields
  • Electronics Dummy compatible
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
Dimensions 190mm x128mm x35mm
Weight G.W 363g
Battery Exclude
Seeeduino ADK Main board 1
Grove - Mega Shield 1
Grove - Chainable LED 3
Grove - Thumb Joystick 1
Grove - PIR Motion Sensor 1
Grove - Temp&Humi Sensor 1
Grove - Ultrasonic Ranger 1
Grove - 125Khz RFID Reader 1
Grove - Relay 2
High Sensitive Mini Servo 1
Grove - X2 Servo cable 1
Grove - Universal 4 Pin cable 10
Micro USB cable 1
