Grove - Base Shield
  • Grove - Base Shield
Grove - Base Shield
SKU 103030014
This product was replaced by a updated version Base Shield V1
$8.90
DISCONTINUED
This product was replaced by a updated version Base Shield V1.3 (SLD01099P).
Base Shield V1.3
This is the new version of Electronic Brick Shield. We standardize all the connectors into 4 pins(Signal 1,Singal 2,VCC and GND) 2mm connectors, which simplify the wiring of electronics projects. The 4pins buckled connectors also make the wiring situation more stable. We build all kinds of Twigs to match up with Stem, still don't you need to worry about the compatibleness between stem and your existing Electronic Bricks.We have many kinks of converter cables(still increasing) to deal with the compatibleness.This is very similar in fashion to an Arduino shield board, and in fact is used as such with our Seeeduino or Mega board.In v1.0b, we move in the analog connectors a little so that it will fit the higher power connector and USB connector.
Base Shield is compatible with Seeeduino or Arduino UNO and Duemilanove.
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
Documents
Please visit our wiki page for more info about this product. It will be appreciated if  you can help us improve the documents, add more demo code or tutorials. For technical support, please post your questions to our forum.
See More
$50 Featured List
$100 Featured List
$200 Featured List
Don’t miss out!
Questions and Answers
SUBMIT
Hi,
could you please tell me if this base shield could or not be used with the Arduino Leonardo ?
http://arduino.cc/en/Main/ardu...
Sincerely thanks.
Mi
on Oct 19,2016
Replyupvote ()
And with Arduino Uno could I use this grove base shield with I2C & SPI ?
on Oct 20,2016 10:46 AM
Replyupvote ()
Reply
0
Hi,
is it possible to use the Gove Base Shield 1.2 with a Seeeduino Ethernet ?
http://www.seeedstudio.com/dep...
Sincerely thanks and have a nic
on Oct 19,2016
Replyupvote ()
And if I use a Relay Shield V2.0 is it possible to put this Base Shield 1.2 on the Relay Shield ?
Replyupvote ()
Reply
0
I use Arduino Uno and Grove Base Shield to read the data from Grove Gyro, Grove Accelerometer and Grove Compass. As I understand, I must connect said sensors to I2C sockets (there are 3 of them on Base Shield). Sensors that connected to I2C-1 and I2C-2
on Oct 19,2016
Replyupvote ()
Hi,only two I2C ports on Base Shield.Please look carefully , G/V/A5/A4 is a anolog port. G/V/A4/A5 is a I2C port.
on Oct 20,2016 10:44 AM
Replyupvote ()
Reply
0
Is it compatible with Seeeduino Stalker v2.2 board? I would like use this base shied for 'Grove - 80cm Infrared Proximity Sensor'.
If it is compatible can I packed it in 'Seeeduino Stalker v2 enclosure' ?
on Oct 19,2016
Replyupvote ()
yes,it is.Base shield is compatible with Seeeduino Stalker.And you can use this base shied for 'Grove - 80cm Infrared Proximity Sensor'But in our test,data is different between Seeeduino and Seeeduino Stalker,may they have a little difference.
on Oct 20,2016 10:42 AM
Replyupvote ()
Reply
See More
Recommended Products
View History
Recommendations
SUBMIT
Invalid email address.
