the AI Hardware Partner
Toggle Nav
Loading...
Grove - Dust Sensor(PPD42NS) - measuring PM 2.5,dual PWM output
This Dust Sensor gives a good indication of the air quality in an environment by measuring the dust concentration.
$9.99
In stock
  • 10+: $8.00
  • Wide measurement range: Not only cigarette smoke, but also indoor dust, an asthma trigger, can be detected.
  • Stable and sensitive measurements: Dual PWM output for particle sizes over 1 micron and 2.5 microns (approx.)
  • Long-term use: Air is self-priming through the current of the air generating mechanism with built-in heater, easy to maintain
  • Compact and light design: Compact size makes installation easier
  • Easy to use: Compatible with Grove port, just plug-and-play
The Particulate Matter level (PM level) in the air is measured by counting the Low Pulse Occupancy time (LPO time) in a given time unit. LPO time is proportional to PM concentration. This sensor can provide reliable data for air purifier systems; it is responsive to PM of diameter 1μm.
What is Grove?
We have developed more than 400 Grove modules, covering a wide range of applications that can fulfil various needs. Click to explore the Grove Sensor family and get started to Grove your Idea. For all Grove users (especially beginners), we provide you with guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your use of the product.
Note
This sensor uses a counting method to measure dust concentration, not the weighing method, and the unit is pcs/L or pcs/0.01cf.
Please pay attention to the warnings listed here.
Application
  • Air Purifier
  • Air Quality Monitor
  • Air Conditioner
  • Ventilator
One More Thing
Dimensions 59mm x45mm x22mm
Weight G.W 28g
Battery Exclude
VCC 4.75~5.75V
Standby Current Supply 90mA
Detectable range of concentration 0~28,000 / 0 ~ 8000 pcs/liter / pcs/0.01cf
Operating Temperature Range 0~45 °C
Output Method Negative Logic, Digital output, High: over 4.0V(Rev.2), Low: under 0.7V
Detecting the particle diameter >1μm
Dimensions 59(W) × 45(H) × 22(D) mm
Humidity Range 95% rh or less
Platform Supported
Grove - Dust Sensor 1
Grove Cable 1
HSCODE 9031809090
USHSCODE 9026104000
UPC 841454108498
EUHSCODE 9013101000
COO CHINA
EU DoC 1
RoHS 1
UK DoC 1
  1. Documentation
    100%
    Product Quality
    100%
    from order view
    Top build quality, still to experiment and test
    By
  2. Documentation
    100%
    Product Quality
    100%
    from order view
    excellent product, works fine
    By
  3. Documentation
    100%
    Product Quality
    100%
    from order view
    This user did not leave any comments.
    By
  4. Product Quality
    100%
    By
  5. Product Quality
    100%
    By
Items 1 to 5 of 10 total
Page
Show per page
