Grove - IMU 9DOF
  • Grove - IMU 9DOF
  • Grove - IMU 9DOF
Grove - IMU 9DOF
SKU 101020059
Please consider Grove - IMU 9DOF v2
$13.50
DISCONTINUED
Please consider Grove - IMU 9DOF v2.0 as alternative product
Grove - IMU 9DOF is a high performance 9-axis motion tracking module,which is base on MPU-9150.The MPU-9150 is the world's first integrated 9-axis motion tracking device designed for the low power, low cost, and high performance requirements of consumer electronics equipment including smartphones, tablets and wearable sensors .MPU-9150 features three 16-bit ADC for digitizing the gyroscope outputs and three 16-bit ADCs for digitizing the accelerometer outputs and three 13-bit ADCs for digitizing the magnetometer outputs.
Specification:
  • I2C interface
  • Low cost
  • 400kHz Fast Mode I2C for communicating with all registers
  • Digital-output X-, Y-, and Z-Axis angular rate sensors (gyroscopes) with a user-programmable full-scale range of ±250, ±500, ±1000, and ±2000°/sec
  • Digital-output 3-Axis accelerometer with a programmable full scale range of ±2g, ±4g, ±8g and ±16g
  • 3-axis silicon monolithic Hall-effect magnetic sensor with magnetic concentrator
Application
Part List:
Documents
Please visit our wiki page for more info about this product. It will be appreciated if you can help us improve the documents, add more demo code or tutorials. For technical support, please post your questions to ourforum.
See More
$50 Featured List
$100 Featured List
$200 Featured List
Don’t miss out!
Questions and Answers
SUBMIT
0
I do connect the IMU-9DOF and load code as taught in WIki. But it doesn't work well. I show the problem in the picture. What should I do now? In the arduino 1.0.5 , there is no board choice for seeeduino.
on Oct 19,2016
Replyupvote ()
Hi Brian, it is better to connect with a G1'1/4 female connection. But sorry that we don't sell this connection now.
on Oct 20,2016 10:42 AM
Replyupvote ()
Reply
0
Where is the link of the red board connecting USB and this IMU 9DOF in the picture of Description? Or other board could do this function is also OK.
on Oct 19,2016
Replyupvote ()
Hi there, sorry there is no datasheet now.But you can refer to our WIKI. About dimension we would put it to WIKI later. Output is pulse from Hall sensor, so there is also have a table for it.
on Oct 20,2016 10:41 AM
Replyupvote ()
Reply
0
Is it possible to read temperature from MPU-9150 and how ???
Thx
on Oct 19,2016
Replyupvote ()
Hi customer, actually the sensor inside are similar. It is calculating the frequency and pipe size to get the result.
Replyupvote ()
Reply
0
Could you please specify the required voltage? There's no info here neither in your wiki. I want to know if I can use this IMU with the Base Shield v1.3 (the one without voltage switch). The MPU's datasheet says it should be < 3.465V
on Oct 19,2016
Replyupvote ()
Hi there, sorry we are not sell the adapter yet.
Replyupvote ()
It can be used with the Base Shield v1.3
on Oct 20,2016 10:50 AM
Replyupvote ()
Reply
See More
View History
Documents
Best-sellers
SUBMIT
Invalid email address.
