seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Grove - LED Strip Driver
      SKU 105020002
      $9.90
      32 Available
      $9.90/1pcs+
      $8.91/10pcs+
      $8.41/20pcs+
      $7.92/50pcs+
      ADD TO CART
      The LED Strip Driver with 4-pin Grove interface provides easy connectivity to your standard Arduino device or Seeed Stalker. It can help you control the luminance of a single-color LED strip, as well as the color and the luminance of an RGB LED strip through Arduino or Seeeduino.
      It has 2 terminals and 2 Grove interfaces. The power for the LED strip comes in through the 2-pin terminal. And the LED controlling voltages output through the 4-pin terminal. The 2 Grove interfaces are respectively screen-printed “IN” (for controlling data input) and “OUT” (for controlling data shared with the next strip driver).
      It can drive an LED strip 1 to 2 meters long with 9 V, while 1 to 5 meters long with 12 V.  The driver in conjunction with the colorful LED strips can add a wonderful effect to indoor or outdoor usages.
      • Grove compatible interface
      • Can be cascaded for a larger display
      • Best results achieved with LED strips 5 meters long or shorter
      • Outputs PWM signals
      • 256 gray-levels are adjustable via programming
      • Arduino and MEGA compatible
      • Screw Terminals (power input and control signal output interface)
      For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
      Documents
      Please visit our wikipage for more info about this product. It will be appreciated if  you can help us improve the documents, add more demo code or tutorials. For technical support, please post your questions to our forum.
      Reviews
      Questions and Answers
      SUBMIT
      0
      0
      If you rotated the"out"grove 4-pin harness 180 degrees, the cable to the next one in line wouldn't have a hard-to-manage twist in it...
      on Oct 19,2016
      Replyupvote ()
      <p>Never mind, I found it. Can I send you my Gerbers so you can verify them before placing my order? Thanks.</p>
      on Oct 20,2016 10:47 AM
      Replyupvote ()
      Reply
      0
      Hello,
      If I wish to connect 4 different LED stripes (each LED strip is composed from 3 different colors LEDs connect together, each color LED is 10cm long). Therefore, is it possible and do I need 4 LED Strip Driver? Will I have some power proble
      on Oct 19,2016
      Replyupvote ()
      <p>Yes. It works now! Thanks!</p>
      Replyupvote ()
      <p>Yes , you need 4 led strip drivers. The numbers of driver you can use are depended on the total load of your circuit. And if you wanna run the same blink code to work with all the stripes in parallel, you can modify the code from wiki: Driver.begin();
      on Oct 20,2016 10:48 AM
      Replyupvote ()
      Reply
      0
      Hi,
      Can you please describe all the components used to build,"In case of two LED strips, upload the DualLEDStrip demo code instead"section in this URL:
      http://
      on Oct 19,2016
      Replyupvote ()
      <p>Two led strip drivers , 9~12v power supply for both two led strip drivers , two led strips , two grove cables , one Seeeduino , one Base shield.</p>
      Replyupvote ()
      Reply
      0
      hello,
      can you tell me the dimensions and holes please.
      Or even better would be a sketch where I can see it.
      many thanks and excuse my english
      regards max
      on Oct 19,2016
      Replyupvote ()
      <p>The diameter of those four holes is 2.2mm.And more information you can refer to the PCB eagle of this product.</p>
      Replyupvote ()
      Reply
      0
      I'm confused by the specification table at http://www.seeedstudio.com/wik...
      My case is that we're going to connect three different color LED strip
      on Oct 19,2016
      Replyupvote ()
      <p>it means if this module connects 5A@12V power supply, the driver current can be upto 3000 mA when the lED Strip is 5m, 3000mA presents the total three channel. <br>for your application, you will connect the three different color LED strips onto 3 LED s
      on Oct 20,2016 10:46 AM
      Replyupvote ()
      Reply
      0
      I am interested in driving 5-7 meters of RGB LEDs (fortunately not all will be on at once). I want to be able to control the ramp on and off times of the LEDs, to be able to turn on individual leds in a random order (eg random controlling a range of 9
      on Oct 19,2016
      Replyupvote ()
      <p>Hi.You can refer to this link(<a href="http://www.seeedstudio.com/forum/viewtopic.php?f=10&t=4438)" rel="nofollow">http://www.seeedstudio.com/for...</a> and just have a try.</p>
      on Oct 20,2016 10:45 AM
      Replyupvote ()
      Reply
      0
      it is possible to wried to raspberry pi gpio
      which pin
      and
      and sample code?
      on Oct 19,2016
      Replyupvote ()
      <p>Hi James Kong.If you use gpio with LED strip Driver directly,you need make a library for it youself.But if you plug a Alamode on Raspberry pi,you can use the same pin and code.</p>
      Replyupvote ()
      Reply
        View History
        SKU 105020002
        $9.90
        32 Available
        ADD TO CART
        $9.90/1pcs+
        $8.91/10pcs+
        $8.41/20pcs+
        $7.92/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
