the AI Hardware Partner
Toggle Nav
Loading...
Grove - Nunchuck
The Grove - NunChuck is a small PCB that adapts the Wii Nunchuck connector to standard Grove connector
$2.90
Out of stock
  • 10+: $2.00
The Grove - NunChuck is a small PCB that adapts the Wii Nunchuck connector to standard Grove connector. The power, ground and two-wire interface of the Nunchuck are all broken out to a 4-pin 0.1"pitch header. This “Grove - NunChuck”, let you play with the Wii Nunchuck and other Wii remote peripherals without needing you to cut cables. Just plug it into the Wii Nunchuck, then into the Grove - Base Shield .
Dimensions 0mm x0mm x0mm
Weight G.W 6g
Battery Exclude
Interface I2C
Work Voltage +5V
Grove - Nunchuck 1
HSCODE 8543909000
USHSCODE 8543708800
UPC 841454107880
EUHSCODE 8543709099
COO CHINA
RoHS 1
Documentations
Documents
