seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Grove - Piezo Vibration Sensor
      SKU 101020031
      $5.90
      19 Available
      $5.90/1pcs+
      $5.31/10pcs+
      $5.01/20pcs+
        I accept the restriction
      This development board can be only used for prototyping, it cannot be built into a product for commercial distribution. It cannot be re-sold or used as part of a production environment.
      Maximum Qty: 5
      Grove- Piezo Vibration Sensor is suitable for measurements of flexibility, vibration, impact and touch. The module is based on PZT film sensor LDT0-028. When the sensor moves back and forth, a certain voltage will be created by the voltage comparator inside of it.
      Therefore, outputs high & low levels. In spite of the fact that it has a high receptivity for strong impacts, a wide dynamic range (0.001Hz~1000MHz) also guarantees an excellent measuring performance. Finally, you can adjust its sensitivity by adjusting the potentiometer with a screw.
      • Standard grove socket
      • Wide dynamic range:0.001Hz~1000MHz
      • Adjustable sensitivity
      • High receptivity for strong impact
      Applications
      • Vibration Sensing in Washing Machine
      • Low Power Wakeup Switch
      • Low Cost Vibration Sensing
      • Car Alarms
      • Body Movement
      • Security Systems
      For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
      Technical Details
      Dimensions40mm x 20mm x 11.5mm
      WeightG.W 12g
      BatteryExclude
      Grove - Piezo Vibration Sensor1
      Reviews
      Questions and Answers
      SUBMIT
      0
      There would be some relationship between the resistance of the potentiometer and the sensitivity. So anyone can tell me the relation. Does the voltage output changes depending upon the sensitivity. Another thing; i want to measure strain produced on a beam using the voltage signal. So is there any conversion factor?
      on Apr 25,2017
      Replyupvote ()
      I want to know the relation between the amplification factor and resistor of the potentiometer.Thanks
      on Apr 25,2017 13:46 PM
      Replyupvote ()
      hi , you can get all you want to konw from [Grove - Piezo Vibration Sensor Schematic PDF File]
      on Jan 09,2018 10:39 AM
      Replyupvote ()
      Where can I find this PDF file?
      on Jan 14,2018 23:09 PM
      Replyupvote ()
      Reply
      0
      May i get chart from pc?(and how?)
      on Oct 19,2016
      Replyupvote ()
      <p>Yes , it is .Please get more information on our wiki.</p>
      on Oct 20,2016 10:42 AM
      Replyupvote ()
      Reply
      0
      What is the power consumption?
      on Oct 19,2016
      Replyupvote ()
      <p><a href="http://www.seeedstudio.com/forum/viewtopic.php?f=17&t=3453&p=13293#p13293" rel="nofollow">http://www.seeedstudio.com/for...</a><br>Hi ,I have rely it here.</p>
      Replyupvote ()
      Reply
      0
      Is the output HIGH /LOW or can I also detect the amount of pressure/vibration (due to changing pressure i the piezo element)
      on Oct 19,2016
      Replyupvote ()
      <p>Sorry,what do you want ?More information ,you can see the wiki.</p>
      Replyupvote ()
      Reply
      0
      puedo ocupar el piezo directamente con arduino?, sin necesidad del shield?, gracias de antemano.
      on Oct 19,2016
      Replyupvote ()
      <p>That is no NEO 6P module now. But if you need large order that you can connect email with us.</p>
      on Oct 20,2016 10:41 AM
      Replyupvote ()
      Reply
      0
      Would like to know if this is compatible with Raspberry PI 2
      on Oct 19,2016
      Replyupvote ()
      <p>Dear customer,<a href="http://www.u-blox.com/images/downloads/Product_Docs/NEO-6_DataSheet_%28GPS.G6-HW-09005%29.pdf" rel="nofollow">http://www.u-blox.com/images/d...</a> This is the datasheet you can see configuration about to set baud rate.<br>It is
      Replyupvote ()
      Reply
      0
      I am investigating an idea for securing equipment in glass cases. The existing security system in place is 24VDC and relies on a dry contact closure change to activate an alarm.
      My question to you is:
      Can we use your device to get the results we
      on Oct 19,2016
      Replyupvote ()
      <p>Hi customer??? if you change to correct baud rate that could get the data.And you know Arduino 2560 is a little different between Arduino Uno or Seeeduino, the pins is changed. So first try to make sure the GPS is work find and then focus on code. Bett
      Replyupvote ()
      Reply
        View History
        SKU 101020031
        $5.90
        19 Available
        Maximum Qty: 5
        $5.90/1pcs+
        $5.31/10pcs+
        $5.01/20pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Learn
        • Reviews
        • Questions and Answers
        • Related
        • View History
        SUBMIT
        Invalid email address.
