Grove - Sunlight Sensor
SKU 101020089
9.90
33 Available
$9.90/ 1pcs+
$8.91/ 10pcs+
$8.41/ 20pcs+
Summer is coming, want to make a UV detector to know the UV index when you are under the sun? Grove - Sunlight Sensor is recommend here.
Grove - Sunlight Sensor is a multi-channel digital light sensor, which has the ability to detect UV-light, visible light and infrared light.
This device is based on SI1145, a new sensor from SiLabs. The Si1145 is a low-power, reflectance-based, infrared proximity, UV index and ambient light sensor with I2C digital interface and programmable-event interrupt output. This device offers excellent performance under a wide dynamic range and a variety of light sources including direct sunlight.
Grove - Sunlight Sensor include an on-bard Grove connector, which help you to connect it your Arduino easily. You can use this device for making some project which need to detect the light, such as a simple UV detector.
  • Digital light sensor
  • Wide spectrum detection range
  • Programmable configuration
  • 3.3/5V Supply
  • Detect sunlight directly
  • Grove compatible
  • I2C Interface(7-bit)
Technical Details
Dimensions140mm x 85mm x 11mm
WeightG.W 9g
BatteryExclude
Operating Voltage 3.0-5.5V
Working current 3.5mA
Wave length 280-950nm
Operating Temperature -45-85oC
Grove - Sunlight Sensor1
Grove Cable1
ECCNEAR99
HSCODE9031900000
Reviews
Questions and Answers
SUBMIT
0
can I hookup, 2-3 together on the same seeedstudio V4.2 with expansion board and still get IR, Vis, UV reading out to the ide?
on Dec 14,2016
Reply upvote ()
Hello, yes you can. You need a software I2C because you can't connect 3 modules in one I2C bus. About software I2C please refer to https://github.com/loovee/Arduino_SoftI2C
on Jan 16,2018 10:09 AM
Reply upvote ()
Reply
0
Hello! kindly tell me how much maximum lux that we can measure using this sensor module?
on Nov 30,2016
Reply upvote ()
It can measures up to 128 klx (direct sunlight). Please refer the following datasheet https://github.com/SeeedDocument/Grove-Sunlight_Sensor/raw/master/res/Si1145-46-47.pdf
on Jan 16,2018 10:10 AM
Reply upvote ()
Reply upvote ()
Reply
1
Will there be a P version for panel mounting / enclosure?
on Sep 07,2018
Reply upvote ()
Hi there, We only have this version this moment. You can remove the connector and solder the cable directly to the 4 pads as temporary solution. thanks.
on Sep 07,2018 09:41 AM
Reply upvote ()
Reply upvote ()
Reply
0
is this compatible with arduino uno? 2nd question what is the meaning of "operting temperature" does it work only on the said temperatures?
on Oct 10,2017
Reply upvote ()
1.YES ! It is compatible with UNO 2.YES !
on Jan 16,2018 10:15 AM
Reply upvote ()
Reply upvote ()
Reply
0
What is the maximum cable length I can use from the sensor to the board?
on Jul 31,2018
Reply upvote ()
Hi, there~this sensor is used I2C to transmit signal,but there is no clear transmission distance specified on the standard. However, the distance of I2C transmission should depend on the stability of the signal, and the stability is determined by factors such as bus load, transmission speed, bus capacitance, and even external interference. Therefore, there may be a problem of changing the communication distance of 5 meters or adding a device. The main thing is to find a way to solve the problem: 1. If it is the actual application, it is necessary to ensure the rising edge and falling edge of the transmission waveform, and the high and low levels can meet the specified requirements to eliminate the influence of the line length. 2. If you only choose the design when designing, the answer above is 25 feet (more than 7 meters). I have used 2 meters in length (normal fine line, in a laboratory environment)
on Aug 03,2018 09:44 AM
Reply upvote ()
Reply
    View History
    SKU 101020089
    $9.90
    33 Available
    $9.90/ 1pcs+
    $8.91/ 10pcs+
    $8.41/ 20pcs+
    • Description
    • Technical Details
    • Learn
    • Reviews
    • Questions and Answers
    SUBMIT
