seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Grove - Temperature&Humidity Sensor (SHT31)
      SKU 101020212
      $11.90
      11 Available
      $11.90/1pcs+
      $11.50/10pcs+
      $10.90/20pcs+
      $9.90/50pcs+
      ADD TO CART
      When we are talking about environmental sensors, we always want it to be accurate, and also easy-to-use. Now, we’ve got a really fine sensor module that has both, the Grove - Temperature&Humidity Sensor (SHT31).
      The SHT31 sensor could be the finest and highest-accuracy humidity sensor you can find, as it can acquire the relative humidity at only ±2% error. On the other side it  also features an excellent performance in terms of temperature measurement, you can use it in some extreme conditions, like -40 degree or 125 degree, and it still keeps an accuracy of ±0.3 degree.
      If you are familiar with our Grove system, you should be aware of how easy it is to get started with such a module that has a GROVE prefix. We design it as a Grove module so you don’t need any bread-boarding, meshing or soldering to make it work.
      If your development board is a Seeeduino, simply connect it to the I2C port and download a few line of code, then you are ready to roll!
      • High accuracy, ±0.3 °C accuracy for temperature and ±2% for humidity
      • Easy-to-use Grove Compatible Interface
      Documents
      • For libraries and documents, please visit our Wikipage.
      • For technical discussion, please come to our Forum.
      • For projects that you would like to share with the community, please visit Recipe.
      NOTE
      As the sensor is quite sensitive to the environmental conditions, please DO NOT touch it with your fingers as you might damage it.
      Technical Details
      Dimensions89mm x 140mm x 7.5mm
      WeightG.W 4g
      BatteryExclude
      Supply Voltage5V or 3.3V
      Current Consumption100 uA
      Temperature Measurement:
      Range-40°C to 125°C
      Accuracy±0.3
      Humidity Accuracy±2%
      Communication InterfaceI2C
      Dimensions20mm x 40mm
      Grove - Temperature&Humidity Sensor (SHT31)1
      Grove Cable1
      Documents
      Reviews
      Questions and Answers
      SUBMIT
        View History
        SKU 101020212
        $11.90
        11 Available
        ADD TO CART
        $11.90/1pcs+
        $11.50/10pcs+
        $10.90/20pcs+
        $9.90/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
