Grove - UV Sensor
Grove - UV Sensor
SKU 101020043
9.90
38 Available
$9.90/ 1pcs+
$8.91/ 10pcs+
$8.41/ 20pcs+
The Grove – UV Sensor is used for detecting the intensity of incident ultraviolet(UV) radiation. This form of electromagnetic radiation has shorter wavelengths than visible radiation. It is based on the sensor GUVA-S12D.It has a wide spectral range of 200nm-400nm. The module will output electrical signal which is varied with the change of the UV intensity. UV sensors are used for determining exposure to ultraviolet radiation in laboratory or environmental settings.
  • High stability
  • Good Sensitivity
  • Low power consumption
  • Schottky type photodiode sensor
  • Wide response range
  • Grove Interface
Technical Details
Dimensions20mm x 20mm x 15mm
WeightG.W 8g
BatteryExclude
Grove - UV Sensor1
Grove Cable1
ECCNEAR99
HSCODE9031900090
Certification
RoHSCompliant
Reviews
Questions and Answers
SUBMIT
0
Hi, I need buy this product but i'm from Chile, Do you ship internationally?
on Jun 07,2018
Reply upvote ()
Hi,gmunoz.yes,we can ship to Chile.Regards~
on Jun 07,2018 09:44 AM
Reply upvote ()
I would be grateful if you could send me a quote for: 20 units, thanks
on Jun 26,2018 23:58 PM
Reply upvote ()
Reply
0
Dear Mr/Ms, would you be so kindly as to update your datasheet with a response-wavelength-diagramm of the current 1.1 version of this product. Kind regards
on Aug 30,2018
Reply upvote ()
Please refer to GUVA-S12SD from https://raw.githubusercontent.com/SeeedDocument/Grove-UV_Sensor/master/res/Grove-UV_Sensor_v1.1_Datasheets.zip . thanks.
on Aug 30,2018 16:17 PM
Reply upvote ()
Reply
0
the index is different with other device,confused
on Apr 14,2018
Reply upvote ()
Hi there~ What do you mean by "index"? Could you please tell us more detail. Regards
on Apr 16,2018 10:09 AM
Reply upvote ()
Reply
    View History
    Grove - UV Sensor
    SKU 101020043
    $9.90
    38 Available
    $9.90/ 1pcs+
    $8.91/ 10pcs+
    $8.41/ 20pcs+
    • Related
    • Description
    • Technical Details
    • Learn
    • Reviews
    • Questions and Answers
    SUBMIT
