Grove - 2-Channel Inductive Sensor (LDC1612)
SKU 101020599
14.95
50+ Available
$14.95/ 1pcs+
$13.45/ 10pcs+
$12.70/ 20pcs+
$11.95/ 50pcs+
The Grove - 2-Channel Inductive Sensor is based on Texas Instruments(TI) LDC1612, a 28-bit inductance to digital converter(LDC) for inductive sensing solutions. With multiple channels and support for remote sensing, the LDC1612 enables the performance and reliability benefits of inductive sensing to be realized at minimal cost and power. Inductance is an effect caused by the magnetic field of a current-carrying conductor acting back on the conductor. So by sensing the inductance, this sensor can detect the proximity of conductors especially metal nearby.
Feature
  • 2 Channels With Matched Sensor Drive
  • Easy-to-Use: Minimal Configuration Required
  • Multiple ChannelsĀ Support Environmental and Aging Compensation
  • Remote Sensor Position of >20 cm Supports Operation In Harsh Environments
Typical applications
  • Knobs in consumer, appliances, and automotive
  • Linear and rotational encoders
  • Buttons in home electronics, wearables, manufacturing, and automotive
  • Keypads in manufacturing and appliances
  • Slider buttons in consumer products
  • Metal detection in industrial and automotive
  • POS and EPOS
  • Flow meters in consumer and appliances
Pin Out
Technical Details
Dimensions60mm x 20mm x 10mm
WeightG.W 12.80g
BatteryExclude
Grove - 2-Channel Inductive Sensor(LDC1612)1
Standalone Circul Coil1
Grove Cable1
ECCNEAR99
HSCODE9031900090
Reviews
Questions and Answers
SUBMIT
    View History
    SKU 101020599
    $14.95
    50+ Available
    $14.95/ 1pcs+
    $13.45/ 10pcs+
    $12.70/ 20pcs+
    $11.95/ 50pcs+
    • Description
    • Technical Details
    • Learn
    • Reviews
    • Questions and Answers
    SUBMIT
