the AI Hardware Partner
Toggle Nav
Loading...
Grove - Barometer Sensor (BMP180)
This is a Grove module for the Bosch BMP180 high-precision, low-power digital barometer
$5.90
Out of stock
This product is retired, please consider Grove - Barometer Sensor(BMP280) as your alternative choice.
This is a Grove module for the Bosch BMP180 high-precision, low-power digital barometer. The BMP180 offers a pressure measuring range of 300 to 1100 hPa with an accuracy down to 0.02 hPa in advanced resolution mode. It’s based on piezo-resistive technology for high accuracy, ruggedness, and long-term stability. The chip only accepts 1.8V to 3.6V input voltage. However, with an outer circuit added, this module becomes compatible with 3.3V and 5V. Therefore, it can be used on Arduino/Seeeduino or Seeeduino Stalker without modification. It is designed to be connected directly to a microcontroller via the I2C bus.
  • Digital two-wire (I2C) interface
  • Wide barometric pressure range
  • Flexible supply voltage range
  • Ultra-low power consumption
  • Low noise measurement
  • Factory-calibrated
  • -40 to +85°C operational range, ±2°C temperature accuracy
  • I2C address: 0x77
Application Ideas
  • Enhancement of GPS navigation
  • Indoor and outdoor navigation
  • Leisure and sports
  • Weather forecast
  • Vertical velocity indication (rise/sink speed)
One More Thing
Dimensions 0mm x0mm x0mm
Weight G.W 7g
Battery Exclude
Grove - Barometer Sensor (BMP180) 1
HSCODE 9026900000
ROHS 1
Documentations
