$1.90
In stock
340+ Available
Qty Discount available
  • $1.71 /10pcs+
  • $1.62 /20pcs+
  • $1.52 /50pcs+
What does “P” mean? “P” is for “panel mount” in this product. This Grove – Button is a sister version of original Grove - Button. They are identical except the Grove connecter is moved to the back so that you can easily use it as a neat and wire-free human interface device.
Dimensions 20mm x20mm x20mm
Weight G.W 8g
Battery Exclude
Grove – Button(P) 1
Grove Cable 1
ECCN EAR99
HSCODE 8538900000
USHSCODE 8536599033
UPC 841454108603
ROHS 1
Example: Push Button
Sample Push Button on Intel Edison in Node.js
BBGW starter tutorial#6 My little alarm clock
Today I make a little alarm clock for myself to remind me sign on. Actually I can use my phone to remind myself. But it doesn’t make me a “maker”. What I enjoy is the process. And I always believe that what I make will truly change my life! Happy hacking!
Grove - Button
Grove - Button is a momentary push button. It contains one independent "momentary on/off" button. “Momentary” means that the button rebounds on its own after it is released. The button outputs a HIGH signal when pressed, and LOW when released. The button
Product Faqs
Sort by
