the AI Hardware Partner
Toggle Nav
Loading...
Grove Inventor Kit for micro:bit
Rating:
100 % of 100
The Grove Inventor Kit for Micro:bit brings endless possibilities to your micro:bit. The core board in this kit is the Grove shield for micro:bit v2.0, with which you can use plenty of Grove modules including sensors, display, actuator to interact with micro:bit.
$65.90
In stock
  • 10+: $49.40
The Grove Inventor Kit for Micro:bit brings endless possibilities to your micro:bit. The core board in this kit is the Grove shield for micro:bit v2.0, with which you can use plenty of Grove modules including sensors, display, and actuator to interact with micro:bit.
  • Multi-module: 8 well-selected Grove modules for working with micro:bit
  • Rich operations: Cool extension shield with rich and convenient peripherals
  • DIY creative Projects: There are different reference projects and Grove sensors for your imagination to create your own project
  • Easy Play: 12 awesome projects to let you get started quickly
  • Grove unified socket: The product ensures "Plug and Play" and could be versatile for various applications.
The BBC micro:bit is a pocket-sized computer that can easily realize your creativity without much electrical and coding knowledge. There are numerous possibilities of creation you can dig out by micro:bit, from robots to musical instruments. However, if you want to create more things, just 1 micro:bit is barely not enough, That’s why we introduce the Grove Inventor Kit for micro:bit to you.
The Grove Inventor Kit for Micro:bit brings endless possibilities to your micro:bit. The core board in this kit is the Grove shield for micro:bit v2.0, with which you can use plenty of Grove modules including sensors, display, and actuator to interact with micro:bit. If you never used and have no idea what grove is, here is the introduction of Grove. All you need to know is that with Grove, there is no need for soldering or jump wires any more. Your prototyping will be easier and much more convenient.
We have already prepared 8 grove modules to let you get started with micro:bit. With these grove modules, you can measure distance and display it, use gestures to play different music, or make a smart guard for your desk or room. We have prepared all the necessary libraries(packages) for free download. If you are a beginner to micro:bit, don't worry because we have also prepared 12 different projects which can teach you step by step. If you are an advanced user, this kit will help you with more creative projects than others.
We have developed more than 400 Grove modules, covering a wide range of applications that can fulfil various needs. Click to explore the Grove Sensor family and get started to Grove your Idea. For all Grove users (especially beginners), we provide you with guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your use of the product.
Application
  • Beginner for Arduino
  • Simple application for Smart Home Control
Specifications
Weight G.W 329.5g
Battery Exclude
Grove Shield for micro:bit v2 1
Grove - Rotary Angle Sensor(P) 1
Grove - Speaker 1
Grove - Ultrasonic Ranger 1
Grove - Light Sensor v1.2 1
Grove - WS2812 Waterproof LED Strip - 30 LEDs 1 meter 1
Grove - Gesture 1
Grove - 4-Digit Display 1
Grove - Red LED 1
Micro USB Cable - 48cm 1
12 Projects Manual 1
Alligator Cable 10
Grove Cable 7
Note
The output voltage of micro:bit is around 3.0V, use microbit or AA battery to power the circuit may cause malfunction of Grove modules which requires high input voltage and drive current(e.g Grove - Ultrasonic Ranger). In order to make these kinds of Grove function well, please use the micro-USB port on Grove shield for microbit to power the circuit.
HSCODE 9023009000
USHSCODE 9023000000
UPC 841454120704
EUHSCODE 9023001000
COO CHINA
EU DoC 1
RoHS 1
UK DoC 1
  1. Product Quality
    100%
    Documentation
    100%
    from order view
    This user did not leave any comments.
    By
1 Item
Show per page
