Grove - Switch(P)
Rating:
100% of 100
What does “P” mean? “P” is for “panel mount” in this product
$2.90
In stock
  • 10+: $2.61
  • 20+: $2.47
  • More
  • 50+: $2.32
  • Less
What does “P” mean? “P” is for “panel mount” in this product. This Grove – Switch is a mini SPDT slide, great for “ON/OFF” situations. It’s such a reliable switch of great build quality that we adopt it on many of our boards. You should stock some for your Grove prototyping system.
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
Dimensions 20mm x20mm x9mm
Weight G.W 8g
Battery Exclude
Input Voltage 3.3V / 5V
Grove - Switch(P) 1
ECCN 3A611.y.21
HSCODE 8538900000
USHSCODE 9031909195
UPC 841454107569
ROHS 1
Using a Switch to Open and Close a Relay
You will learn the value of a switch, with its High and Low function. In addition you will learn how to use a relay as an actuator.
Arduino BoomBox
An Arduino UNO will be used to control the Grove Serial MP3 player by sending it specific serial commands. The Grove Base Shield allows for the easy connection of Grove sensor modules to an Arduino UNO without the need for a breadboard. A sliding potentio
Grove - Switch(P)
This Grove – Switch is a mini SPDT slide, great for “ON/OFF” situations. It is such a reliable switch of great build quality that we adopt it on many of our boards. You should stock some for your Grove prototyping system.
Product Faqs
Sort by
