Go to Checkout
      Your cart is empty
      Grove - Temperature&Humidity Sensor (HDC1000)
      SKU 101020087
      Grove - Temperature&Humidity Sensor (HDC1000) utilizes a HDC1000 sensor, which was designed by Texas Instruments. It is a digital humidity sensor with integrated temperature sensor that provides excellent measurement accuracy at very low power. The device measures humidity based on a novel capacitive sensor. The humidity and temperature sensors are factory calibrated. The innovative WLCSP (Wafer Level Chip Scale Package) simplifies board design with the use of an ultra-compact package. The sensing element of the HDC1000 is placed on the bottom part of the device, which makes the HDC1000 more robust against dirt, dust, and other environmental contaminants. The HDC1000 is functional within the full –40°C to +125°C temperature range, and 0-100% RH range.
      • Grove connector compatible
      • IIC Interface
      • ŸLow Power
      • Wide operating voltage range
      • I2C Serial Bus Address Configuration
      • Supple Voltage: 3~5Vdc;
      • Working Current: 0.12~90uA;
      • Relative humidity accuracy: ±3%RH;
      • Relative humidity operating range: 0~100%RH;
      • Temperature accuracy: ±0.2℃;
      • Temperature range: -40~125℃;
      • Operating temperature: -20~85℃
      • Dimension: 40×20mm.
      • 1x PCBA -Grove - Temperature&Humidity Sensor(HDC1000);
      • 1x 26AWG Grove Cable; SA206120099A.
      Technical Details
      WeightG.W 7g
      Grove - Temperature&Humidity Sensor (HDC1000)1
      26AWG Grove Cable; SA206120099A.1
      Questions and Answers
      Is this waterproof? If not, is there any way to waterproof it?
      on Nov 30,2017
      Replyupvote ()
      Hi there~ Sorry to tell you that this one is not waterproof.And it is hard to make it waterproof.You can try our another product if you need this one to measure the soil.# # and this product is waterproof.
      on Dec 01,2017 10:06 AM
      Replyupvote ()
        View History
        SKU 101020087
        • Best-sellers
        • Description
        • Technical Details
        • Learn
        • Reviews
        • Questions and Answers
        • View History
        Invalid email address.
