seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Grove Zero STEM Starter Kit
      SKU 110060822
      $99.50
      21 Available
      $99.50/1pcs+
      $95.00/10pcs+
      $91.00/20pcs+
      $88.00/50pcs+
      ADD TO CART
      About The Product
      Grove Zero is a series of color-coded and magnetic electronic modules that teaches students about programming, electronics, design thinking, and logics. The modules are plug-and-play and programmable with our computer-based app, or with the drag-and-drop blocks using the Microsoft MakeCode. Students can either just snap them together to make fun creative projects, or get into re-program the modules for advanced projects. With a curriculum that is written by very experienced educators, Grove Zero Kits allows teachers with no experience or lots of experience to bring the detailed lesson plans into their classroom and embed them in their learning system.
      Plug-and-Play
      Modules can be snapped together easily in anyway. For users without any prior electronics experience,there is no wrong way to make a mistake. Modules can be snapped together easily in anyway. For users without any prior electronics experience, there is no wrong way to make a mistake. Thanks to its magnetic connectors, Grove Zero can be connected in any way. For more information about magnetic connections please check this  out.
      Color Coded
      Grove Zero are all color-coded by functions. Pink for the main board, blue for input module, white for output module, and green for battery module.
      Visual Programming
      Grove Zero supports Microsoft MakeCode and Module Matcher, which are easy-to-use visual programming tool enables advanced features.
      Module Matcher
      An entry-level, computer-based app to help you learn the basics of coding as well as practice your logical thinking. You can make simple projects very easilly and quickly, just by pairing up the actions of an input and the reactions of an output.
      [Download] Module Matcher for Windows.zip(Beta Version)
      [Download] Module Matcher for Mac.zip(Beta Version)
      MakeCode
      Microsoft MakeCode for Grove Zero is a web-based code editor for physical computing. It provides a block editor, similar to Scratch or Code.org, and also a JavaScript editor for more advanced users. Try it now at https://makecode.seeedstudio.com/!
      What You Will Get
      (1)Basic Invention Guide
      The Invention Guide provides the fundamentals of Grove Zero modules, helps beginners get started with 6 creative and playful projects and the corresponding instructions.
      [Download] Basic Invention Guide
      (2) Educator's Guides
      8 lessons, including 60+ pages of detailed instruction and teaching tips to help educators bring Grove Zero into their classroom.
      Download Product Overview PDF
      Download Teachers' Guide PDF
      Download Students' Log PDF
      Distributor
      If you locate at Sweden, Switzerland or Germany, you can also purchase Grove Zero STEM Starter Kit via our distributor below:
      Technical Details
      Dimensions273mm x 150mm x 33mm
      WeightG.W 489g
      BatteryExclude
      Main Board MCUAtmel SAMD21G18
      Node MCUSTM32F030F4P6
      Working Voltage3.6V – 5V
      CommunicationI2C
      9-Dof ChipMPU9250
      Light Sensor ChipTSL2561
      Temperature Sensor ChipLM75A
      Sound Sensor ChipLM358
      Module Size
      Basic30mm x 25mm
      Extended50mm x 25 mm
      Main Board1
      LED Matrix1
      Buzzer1
      Twin Button1
      Light Sensor1
      9-Dof1
      Temperature Sensor1
      Sound Sensor1
      Power1
      Reviews
      Questions and Answers
      SUBMIT
      0
      Why I keep loading the makecode.seeedstudio.com website (the Microsoft MakeCode editor)?
      on Nov 20,2017
      Replyupvote ()
      It takes time to download the Microsoft MakeCode editor if it's your first time to visit the makecode.seeedstudio.com on a new computer.
      on Nov 20,2017 21:54 PM
      Replyupvote ()
      Reply
      0
      Why my Module Matcher is not working?
      on Nov 20,2017
      Replyupvote ()
      It might because your Main Board is running a different program you uploaded previously. You can reset your Main Board and try again.
      on Nov 20,2017 21:53 PM
      Replyupvote ()
      Reply
      0
      Why would I need to reset my Main Board?
      on Nov 20,2017
      Replyupvote ()
      The Microbit MakeCode and Module Matcher run different programs. Once you programmed your Main Board with Microsoft MakeCode, you need to reset your Main Board to be able to use Module Matcher again.
      Replyupvote ()
      Reply
      0
      How do I upload the 'uf2' program to my Grove Zero?
      on Nov 20,2017
      Replyupvote ()
      Connect Grove Zero Main Board to a computer with a micro-USB cable and double-press the 'RESET' button on your Main Board to enter the removable disk named 'Grove Zero', then simply move the 'uf2' file to the removable disk the complete the upload.
      Replyupvote ()
      Reply
      0
      What is the 'uf2' file?
      on Nov 20,2017
      Replyupvote ()
      The 'uf2' file is the program than runs on your Grove Zero Main Board.
      Replyupvote ()
      Reply
      0
      Is it available with french instruction for kids ?
      on Oct 31,2017
      Replyupvote ()
      We are now working on French version, we will update it on product page when we finish. Thanks for asking.
      on Nov 20,2017 21:51 PM
      Replyupvote ()
      Reply
        View History
        SKU 110060822
        $99.50
        21 Available
        ADD TO CART
        $99.50/1pcs+
        $95.00/10pcs+
        $91.00/20pcs+
        $88.00/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
