GrovePi+ Starter Kit for Raspberry Pi
SKU 110060050
89.99
DISCONTINUED
GrovePi+ are compatible with Pi 2, please check the details from Dexter blog.
This product was replaced by a updated versionGrovePi+ Starter Kit for Raspberry Pi (CE certified) (110060161).
Carrying a GrovePi+ board together with 12 carefully selective Grove sensors with 10 pieces cables , this starter kit gets you up and running with the Raspberry Pi quickly. Just slip the GrovePi+ board over your Raspberry Pi and connect sensors to the board, you’re ready to start hardware playing and prototyping with the powerful platform.
About The GrovePi+, It is stacked on top of the Raspberry Pi without the need for any other connections. Communication between the two occurs over the I2C interface. All Grove modules connect to the universal Grove connectors on the GrovePi+ shield via the universal 4 pin connector cable.
About Grove modules, which work on analog and digital signals, connect directly to the ATMEGA328 microcontroller on the Grove Pi+. The microcontroller acts as an interpreter between the Raspberry Pi and the Grove sensors. It sends, receives, and executes commands sent by the RaspberryPi.
The GrovePi+ is compatible with Raspberry Pi A+,B,B+/2.
Please be notice: The Raspberry Pi board is not included.
What's include?
grovepikit6.jpgGrove pi+ X1grovepikit10.jpgGrove - Rotary Angle Sensor X1
grovepikit4.jpgGrove - sound Sensor X1grovepikit11.jpgGrove-LCD RGB Backlight X1
grovepikit5.jpgGrove - Temperature&Humidity X1grovepikit12.jpgGrove - red led X1
grovepikit6.jpgGrove - light sensor X1grovepikit13.jpgGrove Buzzer X1
grovepikit7.jpgGrove -Relay X1grovepikit14.jpgGrove blue led X1
grovepikit8.jpgGrove - Button X1grovepikit15.jpgGrove green led X1
grovepikit9.jpgGrove - UItrasonic Ranger X1
Grovepi+Guidebook X1
Cables X10
Document and resoures
Technical Details
Dimensions0mm x 0mm x 0mm
WeightG.W 328g
BatteryExclude
ECCNNot Available
HSCODE9023009000
Documents
Reviews
Questions and Answers
SUBMIT
0
the above grove pi+ robot link is gone, any advice?
on Jul 08,2018
Reply upvote ()
Hi, there~Sorry, we will sovle this ASAP, Regards!
on Jul 09,2018 09:42 AM
Reply upvote ()
Hi, sorry, the product is discontinued now, This product was replaced by a updated versionGrovePi+ Starter Kit for Raspberry Pi (CE certified) (110060161). the link is https://www.seeedstudio.com/GrovePi%2B-Starter-Kit-for-Raspberry-Pi-A%2B%2CB%2CB%2B%26amp%3B2%2C3-%28CE-certified%29-p-2572.html
on Jul 09,2018 09:59 AM
Reply upvote ()
Reply
0
hi , the link is gone, please send me a new one: https://www.seeed.cc/Grove-Pi-Robot-p-190.html
on Jul 08,2018
Reply upvote ()
Reply upvote ()
Hi, there. this product has been sold out, but you can click here for replecment ,Regards! ##https://www.seeedstudio.com/GrovePi%2B-Starter-Kit-for-Raspberry-Pi-A%2B%2CB%2CB%2B%26amp%3B2%2C3-%28CE-certified%29-p-2572.html##
on Jul 09,2018 16:09 PM
Reply upvote ()
Reply
    View History
    SKU 110060050
    $89.99
    DISCONTINUED
    $89.99/ 1pcs+
    • Description
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
