HiFiBerry DAC+ standard RCA
SKU 114990509
34.90
DISCONTINUED
The HiFiBerry DAC+ standard is a high-resolution digital-to-analog converter for the Raspberry Pi (newer models with 40 pin GPIO connector). This is a special sound card for the Raspberry Pi, optimized for one specific use case: the best audio playback quality.
Usage recommendations
  • small and elegant high quality music playback devices
  • home automation and multi-room audio system
  • Dedicated 192kHz/24bit high-quality Burr-Brown DAC with external low-jitter clock for best sound quality.
  • Hardware volume control. You can control the output volume using “alsamixer” or any application that supports ALSA mixer controls.
  • Connects directly to the Raspberry Pi, no additional cables needed
  • No soldering, comes as a pre-fabricated kit. You just plug it onto the Raspberry Pi, it is conform to the Raspberry Pi hardware-attached-on-top (HAT) specification.
  • Compatible with Raspberry Pi models A+, B+ and 2B (Zero when soldering GPIO header)
  • Directly powered from the Raspberry Pi, no additional power supply
  • Ultra-low-noise voltage regulator for optimal audio performance
  • Comes with all components required to mount it. We include 4 M2.5x12mm spacers to fix the board onto the Raspberry Pi.
  • 1 x HiFiBerry DAC+ standard RCA audio board
  • 4 x M2.5x12mm spacers to mount on the Raspberry Pi
For any technical support, please contact our user guides and forum: http://support.hifiberry.com/hc/en-us/
Technical Details
Dimensions0mm x 0mm x 0mm
WeightG.W 30g
BatteryExclude
ECCNNot Available
HSCODE8522909900
Certification
RoHSCompliant
Reviews
Questions and Answers
SUBMIT
    View History
    SKU 114990509
    $34.90
    DISCONTINUED
    $34.90/ 1pcs+
    • Description
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
