the AI Hardware Partner
Toggle Nav
Loading...
HiFiBerry Digi+ standard
The HiFiBerry Digi+ is a high-quality S/PDIF output board for the Raspberry Pi (newer models with 40 pin GPIO connector)
$34.90
Out of stock
  • 10+: $33.16
The HiFiBerry Digi+ is a high-quality S/PDIF output board for the Raspberry Pi (newer models with 40 pin GPIO connector).
Usage recommendations
  • high quality digital audio connection
  • to connect high quality DACs using an optical or electrical output
  • Dedicated S/PDIF interface chip supports up to 192kHz/24bit resolution
  • Optical (Toslink) and electrical outputs
  • Bit-perfect output, audio data stream will not be modified in any way
  • Connects directly to the Raspberry Pi, no additional cables needed
  • No soldering, comes as a pre-fabricated kit. You just plug it onto the Raspberry Pi, it is conform to the Raspberry Pi hardware-attached-on-top (HAT) specification.
  • Compatible with Raspberry Pi models A+, B+ and 2B (Zero after soldering the GPIO header)
  • Directly powered from the Raspberry Pi, no additional power supply
  • Comes with all components required to mount it. We include 4 M2.5x12mm spacers to fix the board onto the Raspberry Pi.
  • 1 x HiFiBerry Digi+ standard audio board
  • 4 x M2.5x12mm spacers to mount on the Raspberry Pi
For any technical support, please contact our user guides and forum: http://support.hifiberry.com/hc/en-us/
Dimensions 0mm x0mm x0mm
Weight G.W 30g
Battery Exclude
HSCODE
ROHS 1
