Non-invasive AC Current Sensor (60A max)
SKU 101990064
6.90
OUT OF STOCK
This item is not available at the moment
Get notified when it's back in stock
Introduction:
What is CT sensors
Current transformers (CTs) are sensors that are used for measuring alternating current. They are particularly useful for measuring whole building electricity consumption (or generation for that matter).
The split core type such as the CT in the picture above, is particularly suitable for DIY use it can be clipped straight on to either the live or neutral wire coming into the building without having to do any high voltage electrical work.
   Features:
   Applications
  •          Suitable for the current measuring
  •          Monitoring and protection of AC motor
  •          Lighting equipment
  •          Air compressor
Specification:
  •          Input Current: 0~60A AC
  •          Output Mode: 0~1V
  •          Non-linearity: ±3%
  •          Build-in sampling resistance(RL): 31Ω
  •          Resistance Grade: Grade B
  •          Work Temperature: -25°C ~ ﹢70°C
  •          Dielectric Strength(between shell and output): 1000V AC/1min 5mA
  •          Leading Wire in Length: 1m
  •          Open Size: 13mm x 13mm
  •         Fire resistance property: in accordance with UL94-VO
Technical Details
Dimensions78mm x 62mm x 25mm
WeightG.W 72g
BatteryExclude
ECCN3A611.y.13
HSCODE9030899090
Certification
RoHSCompliant
Reviews
Questions and Answers
SUBMIT
    View History
    SKU 101990064
    $6.90
    OUT OF STOCK
    $6.90/ 1pcs+
    • Description
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
