Joint Bearing SI4T&K
  • Joint Bearing SI4T&K
SKU 323030022
Spherical plain bearings can withstand a greater load
$1.50
DISCONTINUED
Spherical plain bearings can withstand a greater load. Can bear radial load, axial load or radial, axial joint load simultaneously. Since the outer spherical surface of the inner ring inlaid with composite materials, so that the bearing can be generated in the work of self-lubricating. Generally used for slower swing movement, but also for tilting movement within a certain range of angles, when supporting shaft and shaft housing bore a greater degree when the heart can still work properly.
Specification:
Part List:
  • 1 x Joint Bearing SI4T/K
See More
$50 Featured List
$100 Featured List
$200 Featured List
Don’t miss out!
Questions and Answers
SUBMIT
See More
Recommended Products
Grove - I2C Touch SensorGrove - I2C Touch Sensor
$16.9
ADD TO CART
Grove - Switch(P)Grove - Switch(P)
$2.9
ADD TO CART
Grove - EncoderGrove - Encoder
$4.9
ADD TO CART
Readiymate PT3-D1Readiymate PT3-D1
$19
ADD TO CART
Grove - SPDT Relay(30A)Grove - SPDT Relay(30A)
$9.9
ADD TO CART
Grove - I2C ADCGrove - I2C ADC
$12.9
ADD TO CART
Grove - MOSFETGrove - MOSFET
$3.9
ADD TO CART
View History
Best-sellers
SUBMIT
Invalid email address.
