Loading...
Large Size Components Storage Box - 2 PCs per lot - Pink
You can use this box to store all the small parts, like the IC chips, capacitors, resistors, small screws, nuts, washers and lock washers etc
$2.50
Out of stock
  • 10+: $2.25
  • 20+: $2.13
  • More
  • 50+: $2.00
  • Less
You can use this box to store all the small parts, like the IC chips, capacitors, resistors, small screws, nuts, washers and lock washers etc. The special designed ambient profiles ensure a secured connection with other boxes of the same or different sizes. This feature enables you to make your own box in any configuration you want.
  • Dimension: 63x 75 x 22mm
  • Inside dimension: 60 x 72 x 18mm
Dimensions 150mm x60mm x21mm
Weight G.W 52g
Battery Exclude
Documentations
Learn
