Loading...
A206 Carrier Board for Jetson Nano/Xavier NX/TX2 NX with compact function design and same size of NVIDIA® Jetson Xavier™ NX carrier board
The A206 carrier board has nearly the same design and function with NVIDIA® Jetson Xavier™ NX carrier board but could work well with Jetson Nano module or Jetson TX2 NX module, too. It provides several connectors with industry standard pinouts to support additional functionality beyond what is integrated on the main platform board.
Note
  • The carrier board is specially designed for working with Jetson Nano/Xavier NX/TX2 NX module and we will not include these modules inside.
  • When using Jetson Nano, the wifi module cannot work with SSD together.
  • The 3V RTC battery will not include.
  • USB 2.0: Micro B Connector
  • USB 3.1: Type A Stacked Connectors
  • RTC back-up coin-cell retainer
  • M.2 Key E Socket & M.2 Key M Socket
  • HDMI / DP: HDMI Type A and DisplayPort Stacked Connector
  • Gigabit Ethernet: RJ45 Connector
A206 is a high-performance, interface rich NVIDIA Jetson Nano / Xavier NX/ TX2 NX compatible carrier board, providing HDMI 2.0, Gigabit Ethernet, USB3.0, M.2 key E wifi / BT, M.2 key M, CSI camera, RS232, CAN, PIO, I2C, I2S fans and other rich peripheral interfaces. It has the same functional design and size with the carrier board of NVIDIA® Jetson Xavier™ NX DEVELOPER KIT.
Basically, it can works with an NVIDIA Jetson  module mentioned above to achieve graphic AI applications. To be more specific, with the NVIDIA Jetson Nan/Xavier NX/TX2 NX module assembled, it could support NVIDIA JetPack, which includes a board support package (BSP), Linux OS, NVIDIA CUDA®, cuDNN, and TensorRT™ software libraries for deep learning, computer vision, GPU computing, multimedia processing, and much more. With its multiple camera connectors, it is suitable for complicate AI graphical application such as Automated Optical Inspection, In Video Action, Robot control, Drone, etc. Overall, A206 is ideal for software development within the Linux environment. Standard connectors are used to access Jetson Xavier NX features and interfaces, enabling a highly flexible and extensible development platform.
Application
  • Industrial Automation
  • Robotics
  • Healthcare
  • Computer Vision
  • Education
Specifications
Connector
HDMI Port
2*HDMI Right Angle Vertical Connector
USB 3.0 Type A
4*USB 3.0 Type A Connector
NVIDIA Gigabit Ethernet
1*RJ45 Gigabit Ethernet Connector (10/100/1000)
DC Power
1*DC Input Power TE Connector
FAN Connect
1*Picoblade Header
M.2 KEY E
1*M.2 Key E Connectivity Slot (75-pin)
CSI Camera Connect
2*CSI Camera (15 pos, 1mm pitch)
Multifunctional port
2.0 Pitch 40 PIN
3V Lithium Battery
1*3V backup battery
M.2 KEY M
1*M.2 Key M Slot (75-pin)
NVIDIA Jetson Nano/NX/TX2 NX connector
1*Jetson SODIMM connector, 260-pin
CAN
1*CAN Bus Header (1x4, 2.54mm pitch, RA)
Button Header
1*Button Header (1x12, 2.54mm pitch, RA)
USB Micro Type B
1*USB Micro B, RA Female
RTC
1*RTC Back-up Coin Cell Socket (CR1225)
Comparison Chart
Feature
A203 carrier board
A205 carrier board
A206 carrier board
Module Compatibility
 NVIDIA® Jetson™ Nano/NX/TX2 NX
PCB Size / Overall Size
87mm*52mm
170mm*100mm
100mm*80mm
Display
1*HDMI
2*HDMI
2*HDMI
CSI Camera
1*CSI
6*CSI
2*CSI
Ethernet
1x Gigabit Ethernet (10/100/1000M)
2x Gigabit Ethernet (10/100/1000M)
USB
2* USB 3.0 Type A (Integrated USB 2.0);
1* USB Micro B(Not support power input)
4* USB 3.0 Type A (Integrated USB 2.0);
1* USB 2.0 Type C(Support OTG)
SATA
5 SATA
M.2 Key M
1*M.2 Key M
1*M.2 Key M
M.2 Key E
1*M.2 Key E
1*M.2 Key E
1*M.2 Key E
TF_Card
1* TF_Card
1* TF_Card
USB WIFI Mode
1* Standard USB WIFI Mode(4 pin interface)
Audio
1* Audio Jack;
2* Microphone interface;
2* Speaker interface
SPI Bus
1* SPI Bus(+3.3V Level)
FAN
1* FAN(5V PWM)
2* Fan(12V/5V);
1* FAN(5V PWM)
1* FAN(5V PWM)
CAN
1* CAN
1* CAN
1* CAN
1* 40-Pin
1* 40-Pin
1* 40-Pin
RTC
Battery included
Battery not included
Power Requirements
DC 15V/3A
DC 19V/4.74A (90W MAX)
DC 15V/3A
Operating Temperature
-25° to +80°
-25° to +80°
-25° to +80°
Hardware Overview
1 x A206 Carrier Board
1 x Power Adapter 15V/3A
HSCODE 8543909000
UPC
Documentations
attention icon
Note
A206 Top View.dwg
A206 Bottom View.dwg
Learn
