seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      LinkIt ONE
      This product contains battery, might applys to shipping constriction.
      LinkIt ONE
      SKU 102030002
      $59.00
      32 Available
      $59.00/1pcs+
      $53.10/10pcs+
      ADD TO CART
      LinkIt ONE
      All-in-one features
      All-in-one features
      Includes ARM7 EJ-S™, GSM, GPRS, Wi-Fi, Bluetooth BR/EDR/BLE, GPS, Audio codec, and SD card connector on a single development board
      Rich-Compatibility
      Rich-Compatibility
      Pin-out similar to Arduino boards, including Digital I/O, Analog I/O, PWM, I2C, SPI, UART and power supply, compatible with Grove 4-pin interface
      Strong Extensibility
      Provides various interfaces for connecting to most sensors, peripherals, Groves, and other widgets
      Your Wearable/IoT Turkey Solution
      Easy Prototyping
      You are what you wear. Using LinkIt ONE together with MediaTek LinkIt SDK (for Arduino) you will be able to easily turn your ideas into practical prototypes and make them a reality with the Seeed productization and agile manufacturing service.
      What is LinkIt ONE
      The LinkIt ONE development board is an open source, high-performance board for prototyping Wearables and IoT devices. It's based on the world's leading SoC for Wearables, MediaTek Aster (MT2502) combined with high-performance Wi-Fi (MT5931) and GPS (MT3332) chipsets to provide you with access to all the features of MediaTek LinkIt. It also provides similar pin-out features to Arduino boards, making it easy for you to connect to various sensors, peripherals, and Arduino shields.
      LinkIt ONE is a co-design product by Seeed Studio and MediaTek. It brings together the parties' knowledge in open hardware and industry-leading reference designs for Wearables and IoT devices to create this powerful development board.
      LinkIt ONE development is fully supported on the MediaTek Labs site: check out the LinkIt sectionandregister here to download the SDK, participate in the Forums, and more.
      what is LinkIt ONE
      Schematic Diagram
      Schematic diagram
      LinkIt ONE is built to offer similar pin-out to the popular Arduino boards ,4-pin grove interfaces and peripheral interfaces, making it easy to add sensors, peripherals, and Arduino Shields to LinkIt ONE and create fully featured wearable and IoT device prototypes. Here you can reach some widgets to have a comprehensive understanding of this platform, and we will develop more one after another.
      Package
      LinkIt ONE is paicked in the protective box, along with a quick start guide, pin-out diagram relevant user mannual and accessories. The box is designed to protect the LinkIt ONE from can prevent the shocks and impact. And for retailer which you may hang on the box in your a physical store, the box may include with a pendant from which it can be hung for display.
      Packaging boxLinkIt ONEAntennaPolymer li-ion Battery
      Box
      LinkIt ONE BoardAntennaPolymer li-ion Battery
      Technical Details
      Dimensions108mm x 75mm x 33mm
      WeightG.W 106g
      BatteryLithium Cells/Batteries packed with equipment UN3481 -PI966
      Microcontroller
      ChipsetMT2502A (Aster)
      CoreARM7 EJ-S™
      Clock Speed260MHz
      PCB Size
      Dimensions3.3 x 2.1 inches
      Memory
      Flash16MB
      RAM4MB
      Power
      Battery Jack3.7~4.2V Li-battery
      DC Current Per I/O Pin0.3~3mA
      Digital IO Pins
      Pin Count16 (D0~D13, SDA, SCL)
      Voltage3.3v
      Analog Input Pins
      Pin Count3 (A0, A1, A2)
      Voltage0~5V
      PWM Output Pins
      Pin Count2 (D3 and D9)
      Voltage3.3v
      Max Resolution13bit
      Frequency (Resolution)1.6KHz (13bit) / 50.8KHz (8bit) / 800KHz (4bit)/ (customizable)
      External Interrupts
      Pin Count2 (D2 and D3)
      I2C (master only)
      Set Count1 (SDA, SCL)
      Speed100Kbps, 400Kbps, 3.4Mbps
      SPI (master only)
      Set Count1 (MOSI, MISO, SCK, SS)
      Speed104Kbps~26Mbps
      UART
      Set Count1 (TX/RX)
      Voltage3.3v
      UART on USB
      Set Count1
      Communications
      GSM850/900/1800/1900MHz
      GPRSClass 12
      BluetoothBR/EDR/BLE (Dual Mode)
      Wi-Fi (MT5931)802.11 b/g/n
      Positioning
      GPS (MT3332)GPS/GLONASS/BEIDOU
      User Storage
      Flash10MB
      SD CardUp to 32GB (Class 10)
      Executable Size
      RAM (Code+RO+RW+ZI+Heap)2MB
      LinkIt One1
      Reviews
      Questions and Answers
      SUBMIT
      0
      Hi, Is LinkIt One have FCC and CE certifications ?
      on Apr 13,2017
      Replyupvote ()
      but why CE and FCC marking logos not printed on the board ?
      on Apr 14,2017 19:13 PM
      Replyupvote ()
      ok I got it, it is printed on the other side
      on Apr 15,2017 21:59 PM
      Replyupvote ()
      Reply
      0
      I'm surprised that there is no enclosure for this board... can anyone recommend a good enclosure for this?
      on Dec 19,2017
      Replyupvote ()
      Hi there~ Please check here # https://www.thingiverse.com/ # You may seach what you need here.
      on Dec 21,2017 17:49 PM
      Replyupvote ()
      Reply
      0
      您好 请告知linkit one 蓝牙主机从机设定的代码谢谢
      on Nov 20,2017
      Replyupvote ()
      您好,请您参考这里的链接# http://labs.mediatek.com/api/linkit-one/Lib_Bluetooth.html #
      on Nov 21,2017 09:55 AM
      Replyupvote ()
      Reply
      0
      Can I use the 1W Solar Panel 80X100 to power the Linkit One module?
      on Oct 10,2017
      Replyupvote ()
      Hi,there~The typical voltage of 1W solar panel is 5.5V.It may damage the linkit One.So we do not recommend it.
      on Oct 11,2017 10:34 AM
      Replyupvote ()
      Reply
      0
      Can I buy this in the USA anywhere ?
      on Jul 14,2017
      Replyupvote ()
      Sorry, it is shipped form Hongkong, maybe you can find it on Amazon.
      on Oct 11,2017 10:41 AM
      Replyupvote ()
      Reply
      0
      Hi, is it possible to make HTTPS request with this board using the GPRSClient?
      on May 07,2017
      Replyupvote ()
        View History
        LinkIt ONE
        SKU 102030002
        $59.00
        32 Available
        ADD TO CART
        $59.00/1pcs+
        $53.10/10pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Learn
        • Reviews
        • Questions and Answers
        • Related
        • View History
        SUBMIT
        Invalid email address.
