LinkIt Connect 7681 - Wi-Fi HDK for IoT
SKU 113990100
9.90
34 Available
$9.90/ 1pcs+
The LinkIt™ Connect 7681 development board provides you with easy access to the five GPIO pins and one UART port — each with an LED — of the MediaTek MT7681 chip, to quickly connect peripheral controllers and electronic circuits. The MT7681 — compact Wi-Fi SoC with embedded TCP/IP stack — is provided on the LinkIt™ Connect 7681 module, co-designed with AcSiP. This module, which is only 15 x 18mm, is also available separately for direct integration into your product’s PCB. (Also see LinkIt™ Connect 7681 module).
The LinkIt™ Connect 7681 development board is part of the LinkIt™ Connect 7681 development platform from MediaTek Labs. This development platform delivers you the tools and documentation to prototype your IoT device and create its final design.
  • Access to the five GPIO pins and one UART port provided by MT7681, with attached LEDs
  • Integrated Wi-Fi antenna
  • Power over USB (Micro USB port).
  • Open source hardware reference design, including schematics, layouts and pin details.
  • Chipset Core: MT7681 ANDES N9
  • Clock Speed: 80MHz
  • Flash: 1MB, RAM: 64KB
  • Power: on-board 1A 3.3V voltage regulator (can be powered from USB connector)
  • Connectors: UART/GPIO/SPI pins are available on connectors (100mil/2.54mm pitch), micro USB connector.
  • GPIO Voltage: 3.3V
  • PWM Output pin Count: 5
  • PWM levels: 0~20
  • UART Voltage: 3.3V
  • Wi-Fi Spec: 802.11 b/g/n for Station mode; 802.11 b/g for AP mode
  • Dimensions: 50 x 31 mm
  • Other: Onboard reset push-button
Technical Details
Dimensions75mm x 75mm x 30mm
WeightG.W 44g
BatteryExclude
LinkIt Connect 7681 - Wi-Fi HDK for IoT1
ECCNNot Available
HSCODE8517709000
Reviews
Questions and Answers
SUBMIT
    View History
    SKU 113990100
    $9.90
    34 Available
    $9.90/ 1pcs+
    • Description
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
