seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Lipo Rider v1.3
      Lipo Rider v1.3
      SKU 106990022
      $9.50
      7 Available
      $9.50/1pcs+
      $8.55/10pcs+
      $8.07/20pcs+
      $7.60/50pcs+
        I accept the restriction
      This development board can be only used for prototyping, it cannot be built into a product for commercial distribution. It cannot be re-sold or used as part of a production environment.
      Maximum Qty: 5
      Lipo Rider is a power module with Lipo battery charge management and boost circuit designed for MCU projects with standard USB output interface. It is extremely affordable and easy to use. No programming is required. Plug it in and it works. The internal charger IC handles all the power flow between the various components.
      FEATURES
      • Jst 2.0 connector
      • Stable 5V USB power supply regardless of source
      • Charge/Recharge algorithms built into chip
      • Charge Lithium Polymer Battery through solar power or USB
      • Stable supply voltage through either lithium battery or USB
      • 2 x USB ports let you program your kit while charging your Lithium battery
      • LED indications for battery full or charging states
      • Simple design means extremely affordable
      • Scalable to multiple lithium batteries and large/multiple solar panels through simple end-user modifications
      SPECIFICATION
      • Small Footprint – Dimensions = L42 × W34 × D6.8
      • 900mA maximum charging current for Lithium battery
      • 600mA maximum supply current from Lithium battery
      • Power diodes to prevent back feed from USB device into Lipo battery
      Technical Details
      Dimensions130mm x 90mm x 8.7mm
      WeightG.W 10g
      BatteryExclude
      Lipo Rider V1.31
      Reviews
      Questions and Answers
      SUBMIT
      0
      Hello, is it possible to charge 3.7 Li as 5V Li or there is a specification?
      on Feb 15,2017
      Replyupvote ()
      Hi,there~You can refer to our wiki.
      on Sep 29,2017 15:12 PM
      Replyupvote ()
      Yes,you can.This rider support 3.7V lipo.Regards
      on Oct 16,2017 10:01 AM
      Replyupvote ()
      Reply
      0
      Hi, is it possible to use this board during the day to charge a 3.7 battery with an esp8266 board connected for the output and use the battery load when it's the night (when there is no charge from the solar panel)? I don't need to use my board during the day, only during the night
      on Oct 18,2017
      Replyupvote ()
      Hello Carlier~You can charge the battery during the day, and use it during the night.Since we do not know the power dissipation of your boards , we do know whether the battery can supply power for all night.
      on Oct 18,2017 11:04 AM
      Replyupvote ()
      I don't want necessary to supply power for all night but i want to be sure than during the day, the lipo rider load the battery and at the end...load my board
      on Oct 18,2017 20:13 PM
      Replyupvote ()
      Reply
      0
      Hi! Can I use this with 14V solar panel?And If I connect Lipo only with solar panel&arduino uno(without battery), Is it work?
      on May 27,2018
      Replyupvote ()
      solar panel and arduino uno
      on May 27,2018 12:56 PM
      Replyupvote ()
      Reply
      0
      Hello, if i were to use this product with battery capacity enough to be charged up during the daytime and sustain power throughout the night, will it be a UPS for arduino MCU outdoor ?
      on Sep 26,2017
      Replyupvote ()
      Hi, cksadrian ~Theoretically,you can.
      on Sep 29,2017 15:09 PM
      Replyupvote ()
      Reply
        View History
        Lipo Rider v1.3
        SKU 106990022
        $9.50
        7 Available
        Maximum Qty: 5
        $9.50/1pcs+
        $8.55/10pcs+
        $8.07/20pcs+
        $7.60/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Learn
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
