LoNet - Mini GSM/GPRS/GPS Breakout
  • LoNet - Mini GSM/GPRS/GPS Breakout
SKU 113990096
We have an updated product: LoNet 808 - Mini GSM/GPRS + GPS BreakoutFor customers who had ordered the old version will get the new one for replace
$39.95
DISCONTINUED
For customers who had ordered the old version will get the new one for replace.
LoNet is a GSM and GPS two-in-one function module. It is based on the latest GSM/GPS module SIM808 from SIMCOM, supports GSM/GPRS Quad-Band network and combines GPS technology for satellite navigation.
It features ultra-low power consumption in sleep mode and integrated with charging circuit for Li-Ion batteries, that make it get a super long standby time and convenient for projects that use rechargeable Li-Ion battery. It has high GPS receive sensitivity with 22 tracking and 66 acquisition receiver charnels. Besides, it also supports A-GPS that available for indoor localization.
The module is controlled by AT command via UART and supports 3.3V and 5V logical level. It comes with a mini GPS and GSM antenna, but not includes Li-Po battery. In addition, to use this module, you still need an unlock SIM-Card supporting GPRS service.
FEATURES
  •   • Quad-band 850/900/1800/1900MHz
  •   • GPRS multi-slot class12 connectivity: max. 85.6kbps(down-load/up-load)
  •   • GPRS mobile station class B
  •   • Controlled by AT Command (3GPP TS 27.007, 27.005 and SIMCOM enhanced AT Commands)
  •   • Supports charging control for Li-Ion battery
  •   • Supports Real Time Clock
  •   • Supply voltage range 3.4V ~ 4.4V
  •   • Integrated GPS/CNSS and supports A-GPS
  •   • Supports 3.0V to 5.0V logic level
  •   • Low power consumption, 1mA in sleep mode
  •   • Supports GPS NMEA protocol
  •   • Compact size 27mm x 46mm x 7mm
  •   • Standard SIM Card
SPECIFICATION
  •   • Receiver channels: 22 tracking / 66 acquisition
  •   • Coarse/Acquisition code: GPS L1
  •   • Tracking sensitivity: -165dBm
  •   • Cold start time: 30s (typ.)
  •   • Hot start time: 1s (typ.)
  •   • Warm start time: 28s (typ.)
  •   • Horizontal position accuracy: < 2.5m CEP
  •   • Power consumption - Acquisition: 42mA
  •   • Power consumption - Continuous tracking: 24mA
  •   • Update rate: 5Hz
PART LIST
  •   • 1 x LoNet - Mini GSM/GPRS/GPS Breakout
  •   • 1 x GPS Passive Antenna - 20dB Gain
  •   • 1 x GSM Antenna - 3dB Gain
  •   • 1 x 9Pin Male Header
DOCUMENTS
See More
$50 Featured List
$100 Featured List
$200 Featured List
Don’t miss out!
Questions and Answers
SUBMIT
0
Hi, just to be sure using this module can i use it as a simple GPS only ? is there a way to switch between GPS / AGPS mode ? can i send and receive sms and calls ?
on Oct 19,2016
Replyupvote ()
Yes, it can be used as a simple GPS only, and also can be used for sending and receiving sms/calls. Regarding the GPS and AGPS mode, they can be switched by AT command.
on Oct 20,2016 10:50 AM
Replyupvote ()
Thank you exactly what i wanted to hear.
Replyupvote ()
Reply
0
Hi, lonet support 3g sim?
on Oct 19,2016
Replyupvote ()
Yes it supports 3g sim (USIM) but sim808 chip can't connect to 3G networks
Replyupvote ()
How can it support 3g but at the same time not be able to connect to 3g networks?
Replyupvote ()
Some sims can connect to both 3G and 2G networks (In my country all the sims I have tried, three different networks, can do that). In this device for example, the sim would connect to a 2g network.
Replyupvote ()
Reply
0
Hi , what is the connection , If I want to connect the LoNet-Mini to Arduino with power from Arduino and without Battery .
on Oct 19,2016
Replyupvote ()
The arduino can't provide enough milliAmps to the sim808 chip
Replyupvote ()
Reply
See More
View History
Best-sellers
SUBMIT
Invalid email address.
