LoNet 808 - Mini GSM&GPRS + GPS Breakout
  • LoNet 808 - Mini GSM&GPRS + GPS Breakout
SKU 113990107
  • Quad-band 850/900/1800/1900MHz
  • GPRS multi-slot class12 connectivity: max. 85.6kbps(down-load/up-load)
  • Integrated GPS/CNSS with A-GPS support
  • Built-in charging circuit for Lipo batteries
  • Low power consumption
    $39.95
    8 Available
    Qty:
    This field is required
    ADD TO CART
    $39.95/1pcs+
    $37.95/10pcs+
    This board based on the latest SIMCOM SIM808 GSM/GPS module, it offers cellular GSM and GPRS data along with GPS technology for satellite navigation.
    The board features ultra-low power consumption in sleep mode, giving the project incredibly long standby times. Furthermore there's an onboard battery charging circuit that can be used with LiPo batteries.
    The GPS receiver is incredibly sensitive with 22 tracking and 66 acquisition channels, and also supports assisted-GPS (A-GPS) for indoor localisation.
    The board is controlled by AT command via UART and supports 3.3V and 5V logical level. It comes with a mini GPS and GSM antenna, however a battery is optional.The board uses the 2G (not 3G or LTE) GSM networks.
    • GPRS mobile station class B
    • Controlled by AT Command (3GPP TS 27.007, 27.005 and SIMCOM enhanced AT Commands)
    • Supports charging control for Li-Ion battery
    • Supports Real Time Clock
    • Supply voltage range 3.4V ~ 4.4V
    • Integrated GPS/CNSS and supports A-GPS
    • Supports 3.0V to 5.0V logic level
    • Low power consumption, 1mA in sleep mode
    • Supports GPS NMEA protocol
    • Compact size 27mm x 46mm x 7mm
    • Standard SIM Card
    GPS Specification
    • Receiver channels: 22 tracking / 66 acquisition
    • Coarse/Acquisition code: GPS L1
    • Tracking sensitivity: -165dBm
    • Cold start time: 30s (typ.)
    • Hot start time: 1s (typ.)
    • Warm start time: 28s (typ.)
    • Horizontal position accuracy: < 2.5m CEP
    • Power consumption - Acquisition: 42mA
    • Power consumption - Continuous tracking: 24mA
    • Update rate: 5Hz
    • 1x LoNet 808 - Mini GSM/GPRS + GPS Breakout
    • 1x mini GPS passive antenna
    • 1x GSM antenna
    Document
    • For any technical support and suggestions, please visit our wikipage.
    • Technical support: deray@deegou.com
    See More
    $50 Featured List
    $100 Featured List
    $200 Featured List
    Don’t miss out!
    View History
    Documents
    Best-sellers
    SUBMIT
    Invalid email address.
