PCB
Base Material
FR-4 is the most commonly used material for PCBs. One sided aluminum boards have traces on one side and bare aluminium on the other. They are good for heat dissipation. For multi-layer aluminium PCBs please use the Advanced service. Flexible Printed Circuit boards (FPC) are much thinner than FR-4 and can be bent to some extent. Learn More
PCB Assembly
FREE express shipping & FREE DFA review for all PCBA orders. NDA supported.
Please log in/create an account before uploading your file.
PCBA QtyThe qty of PCBA should be less than the qty of PCB.
How to shorten the PCBA production time without paying more? Check out Seeed's 150,000+ in-stock OPL Now
Please make a BOM file which follows this template so that the website can read it correctly. Learn More
ABCD
1DesignatorManufacturer Part Number or Seeed SKUQtyLink
2C1,C2,C3,C4,C5RHA0J471MCN1GS5https://www.digikey.com.cn
3A1,A4RH0111-300022https://statics3.seeedstudio.com
4D1CYBLE-014008-001https://www.digikey.com.cn
  • We only recognize commas to distinguish the location.
  • The designator number should be ≤ Qty.
  • MPN is the Manufacturer Part Number, NOT Digikey or Mouser Part Number, can also write the Seeed SKU.
  • Do not include components in the BOM that you do not need us to solder onto the boards.
Visual Inspection
(Free for each PCBA)
After assembly, each PCBA will undergo visual inspection to gauge assembly quality, e.g. solder joints and component placement. This service comes free with all PCBA assembled in Fusion.
Functional Test
(Highly recommended for all PCBA orders)
Functional testing is a paid service that verifies that the assembled device functions as intended as per the design. You will be asked to supply additional documents on how the PCBA is expected to perform. More information.
The contents of the file must be as shown.
  • We only recognize commas to distinguish the designator.
  • The designator should be ≤ Qty.
  • MPN is the Manufactured Part Number, NOT Digikey or Mouser Part Numer.
A1,A4222222223180200102
D1CYBLE-014008-001
LocationManufacturer Part Number or Seeed SKUQuantity
C13020100071
D1,D2ATMEGA168PA-MU2
Loading
{{ isBomAnalysisDes }}
There are {{ bomResultCount }} component(s) in your BOM
There are {{ bomResultCount+bomEnquiryCount }} component(s) in your BOM, while there are {{ bomEnquiryCount }} Manufacturer Part Numbers (MPN) that could not be matched by our system. Please provide product description links for the unmatched parts and add the order to your shopping cart. We will check the data manually and update the quotation within one working day.
 DesignatorMPNQuantityPurchase Link
{{ item.designator }}{{ item.mpn }}{{ item.qty == 0 ? 0 : item.qty }} * {{ bomQty }}
Component providerDesignatorManufacturePart NumberSeeed SKUDescriptionQuantityWaste quantityWaste materialQuanity required
Customer{{ item.designator }}{{ item.mpn }}{{ item.sku }}{{ item.description }}{{ item.qty }}{{ item.waste_qty }}{{ item.waste_qty*1 + item.need_qty*1 }}
 DesignatorMPNSeeedSKUDescriptionQuantityWaste quantityUnit PriceAmountProcurement Time
{{ item.designator }} {{ item.mpn }} //
{{ item.qty }} * {{ bomQty }}//
MPNDescriptionUnit PriceAmountProcurement TimeActions
{{ component.mpn }} {{ component.description }}{{ component.unit_price | isShowFree}}{{ component.unit_price*item.query.qty | isShowFree}}{{ component.lead_time }}use
{{ item.designator }}{{ item.mpn}}{{ item.sku }}{{ item.description }}{{ item.qty}} * {{ bomQty }}{{ item.waste_qty }}{{ item.unit_price | isShowFree }}{{ item.unit_price * item.qty * bomQty + item.waste_qty * item.unit_price | formatNumberFixed 4 | isShowFree}}{{ item.lead_time }}
SMT Stencil
Can't find what you are looking for? Try the Fusion Advanced PCB service or send us a message at pcb@seeed.cc and we will aim to reply within one working day. Please do not leave special requirements on the order form. This is for logistics purposes only and will be ignored during the production stage.
To save on disappointment, please double check your design files for errors in our Online Gerber Viewer or otherwise. We will not be held responsible for errors in the files. Visit the Fusion FAQ for our specification, guides, tips and tricks and important design considerations.
Seeed Fusion's privacy policy protects your data. We will not disclose your personal information or fabrication data with external parties for any purpose other than for the manufacture of your goods. You are of course, welcome to share your designs with the open community in the Fusion Gallery. There, anyone can download your design, modify or manufacture them for their own purposes.
Fusion offers one stop prototyping services for PCB (Printed Circuit Board), PCBA (PCB Assembly) and other electronic and mechanical customized services such as CNC milling, 3D printing and PCB layout services. Seeed Fusion promises mature PCB manufacturing and fabrication with low costs, quick build time and 100% quality guaranteed. We are a Chinese manufacturer trusted by millions of electronic engineers, hobbyist and makers around the world. And here's why:
Instant Online Quote without hidden costs
Quick Turnaround from 24 hours build time
Over 10 years Industrial Expertise
Professional and Considerate technical support
PCB Cost
{{ pcbOrgPriceByCurr | formatCurrency}}
PCBA Cost
{{ BOMTotalPriceByCurr |formatCurrencyFree 'original' }}{{ BOMTotalPriceByCurr |formatCurrencyFree 'original' }} {{ BOMTotalPriceByCurrOrigin |formatCurrency 'original' }}
  • Setup Cost
    {{ BOMsetupCostByCurrOrigin |formatCurrencyFree 'original' }}{{ BOMsetupCostByCurr |formatCurrencyFree 'original' }}{{ BOMsetupCostByCurrOrigin |formatCurrencyFree 'original' }}
  • Consumptive Material Cost
    {{ BOMconsumptiveMaterialCostByCurrOrigin |formatCurrencyFree 'original' }}{{ BOMconsumptiveMaterialCostByCurr |formatCurrencyFree 'original' }}{{ BOMassemblyCostByCurrOrigin |formatCurrencyFree 'original' }}
  • Assembly Cost
    {{ BOMassemblyCostByCurrOrigin |formatCurrencyFree 'original' }}{{ BOMassemblyCostByCurr |formatCurrencyFree 'original' }}{{ BOMassemblyCostByCurrOrigin |formatCurrencyFree 'original' }}
  • Component Cost
    {{ BOMcomponentsCostByCurrOrigin |formatCurrencyFree 'original' }}{{ BOMcomponentsCostByCurr |formatCurrencyFree 'original' }}{{ BOMcomponentsCostByCurrOrigin |formatCurrencyFree 'original' }}
  • Operation Fee
    {{ BOMoperationFeePriceByCurrOrigin |formatCurrencyFree 'original' }}{{ BOMoperationFeePriceByCurr |formatCurrencyFree 'original' }}{{ BOMoperationFeePriceByCurrOrigin |formatCurrencyFree 'original' }}
Additional Service
{{ BOMAddPriceByCurr |formatCurrencyFree 'original' }}{{ BOMAddPriceByCurr |formatCurrencyFree 'original' }}{{ BOMAddPriceByCurrOrigin |formatCurrency 'original' }}
  • {{ BOMExpeditedCostByCurrOrigin |formatCurrencyFree 'original' }}
  • Expedited Production Time{{ finalExpeditedBuildTime }} Working Days
  • {{ BOMDFACostByCurr |formatCurrencyFree 'original' }}{{ BOMDFACostByOrigin |formatCurrencyFree 'original' }}{{ BOMDFACostByOrigin |formatCurrencyFree 'original' }}
  • DFA Review Time+2 Working Days
PCBA Tier Price
NEW
  • Qty
    Per Piece
    total
  • {{qty1}}
    {{total1/qty1 |formatCurrencyFree 'original' }}
    {{total1 | formatCurrencyFree 'original' }}
    loading...
  • {{qty2}}
    {{total2/qty2 |formatCurrencyFree 'original' }}
    {{total2 | formatCurrencyFree 'original' }}
    loading...
  • {{qty3}}
    {{total3/qty3 |formatCurrencyFree 'original' }}
    {{total3 | formatCurrencyFree 'original' }}
    loading...
  • {{qty4}}
    {{total4/qty4 |formatCurrencyFree 'original' }}
    {{total4 | formatCurrencyFree 'original' }}
    loading...
Stencil Cost
{{ stencilOrgPriceByCurr | formatCurrency }}
  • PCB Dimensions{{ stencilResult.s_dimensions_name }}
  • Stencil Quantity{{ stencilResult.s_qty }}
  • Fiducial Mark{{ stencilResult.s_fiducial.name }}
  • Thickness{{ stencilResult.s_thickness.name }}mm
  • Polishing Techniques{{ stencilResult.s_polishing.name }}
Expedited Cost
This is a rush order option, which for speeding up the PCB production time.
  • {{ item.name }}{{ item.price | formatCurrency }}
* If you want to sign a NDA regarding your orders, please contact us at fusion@seeed.cc
* The cost of pending items is subject to manual review. Please add the order to the cart, and we will review and update the quotation within one working day.
* Your final payment is subject to our review for the component(s) that our system can't match.
