Medium Size Components Storage Box - 5 PCs per lot - Green
You can use this box to store all the small parts, like the IC chips, capacitors, resistors, small screws, nuts, washers and lock washers etc
- 10+: $4.68
You can use this box to store all the small parts, like the IC chips, capacitors, resistors, small screws, nuts, washers and lock washers etc. The special designed ambient profiles ensure a secured connection with other boxes of the same or different sizes. This feature enables you to make your own box in any configuration you want.
Dimension: 70mm X 30mm X 20mm
Inside dimension: 66 x 18mm x 16mm
Box Color: Green
5 PCs per lot
Dimensions | 375mm x30mm x23mm |
Weight | G.W 82g |
Medium Size Components Storage Box - 5 PCs per lot - Green | 1 |
HSCODE | 3923100090 |
USHSCODE | 3923210030 |
UPC | 841454105947 |
EUHSCODE | 3923101000 |
COO | CHINA |
RoHS | 1 |
from order viewQuality is good
Show
per page
