the AI Hardware Partner
Toggle Nav
Loading...
Mini 125Khz RFID Module - Pre-Soldered Antenna (70mm Reading Distance)
This RFID module is designed for reading code from 125Khz card compatible read-only tags and read/write card
$9.90
Out of stock
  • 10+: $8.91
  • 20+: $8.42
  • More
  • 50+: $7.92
  • Less
This RFID module is designed for reading code from 125Khz card compatible read-only tags and read/write card. It will notify whenever 125Khz tag approaches, the tag serial number will be send via TX pin or Wiegand pin. Super small size design, it is widely applied in office/home security, personal identification, access control, anti-forgery, interactive toy and production control systems etc.
  • Small Outline Design
  • Pre-Soldered Mini Antenna
  • UART TTL Interface
  • Maximum Effective Distance Up To 75mm
  • Support EM4100 Compatible Read Only or Read/Write Tags
  • Working Frequency: 125Khz
  • Baud Rate: 9600
  • Interface: TTL or Wiegand26
  • Working Voltage: DC 3.3V - 5V
  • Working Current: 19mA - 25mA
  • Reading Distance: Max.70mm
  • Working Temperature: -10℃ to +70℃
  • Storage Temperature: -20℃ to +80℃
  • Humidity: 0% - 95%
  • Antenna Dimension: 60 x 35 x 2.5mm
  • Antenna Inductance: 388uH
  • PCBA Dimension: 18 x 13 x 3.7mm
Software
Dimensions 60mm x90mm x11mm
Weight G.W 5g
Battery Exclude
ECCN 5A992
HSCODE 8517709000
