seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Multi Chassis-4WD Robot Kit (ATV version)
      SKU 110990087
      $45.00
      OUT OF STOCK
      This item is not available at the moment
      Get notified when it's back in stock
      Robot Multi Chassis 4WD kit build with full metal frame and special texture wheel. Benefit by the metal frame and the special wheel, this robot is good for heavy loading, and easy to run on sand, lawn or something else like that.
      • Strong and durable Aluminum alloy chassis
      • Full metal frame
      • Special texture wheel
      Specifications
      • Size: 178*145*78cm (length*width*height)
      • Wheel diameter: Φ78MM
      • High-quality ATV wheel (rubber wheel): 4pcs
      • DG01D motor 48: 1 ratio gear: 4pcs(Metal output shaft)
      • Net weight: 580g
      • 5x AAA battery holder
      • Supply voltage: 6v-9v
      • Nominal current: 800mA
      • Stall current: 2800mA
      • 1 x Aluminum chassis top
      • 1 x Aluminum chassis bottom
      • 4 x DC motor
      • 4 x Racing wheel
      • 4 x Distance holder M3*25
      • 6 x M3*8 flat-head screw
      • 4 x M2.5*20 screw
      • 4 x M2.5*25 screw
      • 4 x M3*22 screw with flange
      • 8 x M3*8 screw
      • 8 x M2.5 nylon nut
      • 2 x M3 nut
      • 1 x 5*AA battery holder
      • 1 x Spanner (M2.5 & M4)
      • 1 x Spanner (M2 & M3)
      • 1 x Screw driver
      Documents
      Technical Details
      Dimensions185mm x 160mm x 100mm
      WeightG.W 772g
      BatteryExclude
      Reviews
      Questions and Answers
      SUBMIT
      0
      Qualidade acima do esperado, todas as pe?as s?o excelentes, super fácil para montar, acompanha tudo que se necessita para fazer a montagem.
      Very good quality, very easy to assemble, the kit comes completely to do all the assembly.
      on Oct 19,2016
      Replyupvote ()
      <p>Thanks for you feedback and provide the link, we would consider about it.Thanks again :).</p>
      on Oct 20,2016 10:41 AM
      Replyupvote ()
      Reply
        View History
        SKU 110990087
        $45.00
        OUT OF STOCK
        $45.00/1pcs+
        $40.50/10pcs+
        $38.25/20pcs+
        $36.00/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
