the AI Hardware Partner
Toggle Nav
Loading...
Non-invasive AC Current Sensor (10A max)
Rating:
100 % of 100
Input Current: 0~10A AC Output Mode: 0~1V Non-linearity: ±3%
$6.90
In stock
  • 10+: $5.87
Introduction:
What is CT sensors
Current transformers (CTs) are sensors that are used for measuring alternating current. They are particularly useful for measuring whole building electricity consumption (or generation for that matter).
The split core type such as the CT in the picture above, is particularly suitable for DIY use it can be clipped straight on to either the live or neutral wire coming into the building without having to do any high voltage electrical work.
Features:
Applications
  • Suitable for the current measuring
  • Monitoring and protection of AC motor
  • Lighting equipment
  • Air compressor
Specification:
  • Open Size: 13mm x 13mm
  • Leading Wire in Length: 1m
  • Dielectric Strength(between shell and output): 1000V AC/1min 5mA
  • Work Temperature: -25°C ~ ﹢70°C
  • Resistance Grade: Grade B
  • Build-in sampling resistance(RL): 186Ω
  • Non-linearity: ±3%
  • Output Mode: 0~1V
  • Input Current: 0~10A AC
  • Fire resistance property: in accordance with UL94-VO
Dimensions 80mm x25mm x65mm
Weight G.W 72g
Battery Exclude
HSCODE 9030899090
USHSCODE 9026104000
UPC 841454105480
EUHSCODE 9013101000
COO CHINA
CE 1
EU DoC 1
RoHS 1
UK DoC 1
  1. Product Quality
    100%
    Documentation
    100%
    from order view
    This user did not leave any comments.
    By
1 Item
Show per page
