seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Non-invasive AC Current Sensor (30A max)
      SKU 101990028
      $9.50
      30 Available
      $9.50/1pcs+
      $8.55/10pcs+
        I accept the restriction
      This development board can be only used for prototyping, it cannot be built into a product for commercial distribution. It cannot be re-sold or used as part of a production environment.
      Maximum Qty: 5
      What is CT sensors
      Current transformers (CTs) are sensors that are used for measuring alternating current. They are particularly useful for measuring whole building electricity consumption (or generation for that matter).
      The split core type such as the CT in the picture above, is particularly suitable for DIY use it can be clipped straight on to either the live or neutral wire coming into the building without having to do any high voltage electrical work.
      Applications
      • Suitable for the current measuring
      • Monitoring and protection of AC motor
      • Lighting equipment
      • Air compressor
      Specifications
      • Input Current: 0~30A AC
      • Output Mode: DC 0~1V
      • Non-linearity:2-3%
      • Build-in sampling resistance(RL): 62Ω
      • Turn Ratio: 1800:1
      • Resistance Grade: Grade B
      • Work Temperature: -25°C ~ ﹢70°C
      • Dielectric Strength(between shell and output): 1000V AC/1min 5mA
      • Leading Wire in Length: 1m
      • Open Size: 13mm x 13mm
      Technical Details
      WeightG.W 72g
      BatteryExclude
      Non-invasive AC Current Sensor (30A max)1
      Reviews
      Questions and Answers
      SUBMIT
      0
      This is a different current sensor than the one they are using in your energy monitor links. This one outputs a voltage, the energy monitor is like your 0-100a current sensor and outputs a current. So you can't hook this one up like shown in the energy monitor links.
      on Nov 07,2017
      Replyupvote ()
      Hi ~You are right, the output is voltage range from 0-1V.You can get the current if you do some math.For more information please refer to the link below. ### https://learn.openenergymonitor.org/electricity-monitoring/ct-sensors/yhdc-ct-sensor-report ###.Regards
      on Jan 12,2018 18:05 PM
      Replyupvote ()
      Reply
        View History
        SKU 101990028
        $9.50
        30 Available
        Maximum Qty: 5
        $9.50/1pcs+
        $8.55/10pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
