PLL FM(88~108MHz) Stereo Audio Transmitter Module
  • PLL FM(88~108MHz) Stereo Audio Transmitter Module
SKU WLS03281M
  • Due to New Year Holidays new orders are going to be processed after Jan 3, 2013
  • This is a PLL FM Stereo Audio Transmitter Module that can stereo-transmit voice/music signals wirelessly to FM Radios(Radio & Receiver)
    $9.90
    DISCONTINUED
    This is a PLL FM Stereo Audio Transmitter Module that can stereo-transmit voice/music signals wirelessly to FM Radios(Radio & Receiver).
    While generally used transmitters work on a single or several pre-determined frequencies, it can transmit any stereo signals of any frequency within the range of 88-108MHz.
    Miniature-sized to fit into any of your products, it is especially easy to install in electronic devices of compact size.
    It can serve as a miniature transmitter itself.
    • Stereo transmission of all broadcast band(88-108MHz).
    • PLL system guarantees good frequency stability.
    • Miniature-sized(SMD Type), easy to apply to any of your products.
    • Controllable from CPU(MCU).
    • Works on a single voltage DC 3.3V.
    See More
    $50 Featured List
    $100 Featured List
    $200 Featured List
    Don’t miss out!
    Questions and Answers
    SUBMIT
    0
    Could you source some decent fixed antennas perhaps? Sure, wire antennas work ok but I prefer something more rugged, a SMD chip antenna maybe?
    on Oct 19,2016
    Replyupvote ()
    Hi, thx for your feedback , you could send your require to our wish(http://www.seeedstudio.com/wis... , then we will consider it. Thx!
    on Oct 20,2016 10:45 AM
    Replyupvote ()
    Reply
    0
    Has anybody made anything with this? I'm trying to, and while I can hear the transmission there's a LOT of noise.
    Also, I've no idea about the antenna aspect!
    on Oct 19,2016
    Replyupvote ()
    Dear Faizan.This is just a little module,you need combine it to other components in order to decrease noise.
    on Oct 20,2016 10:43 AM
    Replyupvote ()
    I sent the wrong file. I sent a 16 channel 480 watt led dimmer, not a HV wiring board.
    I apologise and am sending the correct file.
    on Oct 20,2016 10:46 AM
    Replyupvote ()
    Reply
    0
    This module BELIEVED FOR A FOLLOWER OF BIRDS (... BEEP ..... BEEP BEEP. .....), what do you recommend, greetings.
    on Oct 19,2016
    Replyupvote ()
    Hi VICENTE , can you provide more details that how does this module can not work.
    on Oct 20,2016 10:42 AM
    Replyupvote ()
    Reply
    0
    The manual lists the RF output as under -3dBm which is about .5mW, is that correct? I believe that's what the previous question was in regards to.
    on Oct 19,2016
    Replyupvote ()
    Yes, you are right.
    on Oct 20,2016 10:41 AM
    Replyupvote ()
    Reply
    0
    Power?
    on Oct 19,2016
    Replyupvote ()
    Hi there,It is works on DC 3.3V.Thanks.
    Replyupvote ()
    Reply
    See More
    View History
    Recommendations
    SUBMIT
    Invalid email address.
