PSK-CM8JL65-CC5 ToF Infrared Distance Measuring Sensor
$26.90
Out of stock
  • 2+: $24.90
  • 50+: $22.90
  • By detecting the phase difference of the light pulse to perceive the distance between the target, sensor can achieve the millimeter resolution.
  • The unique HALIOS photoelectric detection technology enhances the strong light immunity, adapts to the outdoor strong sunlight environment, has strong temperature adaptability and small drift.
  • Solid solution; limited influence by color of target and Surface roughness and material in testing result.
  • Small size, small photosensitive surface, low product height
  • Connection:4 core, 0.8mm spacing connector
  • Item: PSK-CM8JL65-CC5
  • Voltage: 5VDC
  • Current: ≤85mA
  • Light source: Infrared LED (850nm)
  • Ambient light: 100.0001x
  • Divergence angle: ±1.4°
  • Output: UART-TTL
  • Response efficiency: 25HZ
  • Testing range: 0.17-8m
  • Resolution: 1mm
  • Repeatability: 6%
  • Detection accuracy: 5%
  • Color sensitivity: ≤10%
  • Temperature: -15 to +55°C
  • Protection level: IP50
  • Material: ABS
  • Connection: 4 core, 0.8mm spacing connector
  • Weight: ≤10g
Connection Diagram:
Dimension:
ECCN 6A992
HSCODE 9031809090
USHSCODE 90318080
Product Faqs
Sort by
