Particle Photon Maker Kit: Everything you need to start building simple Internet enabled projects
SKU 110060705
89.00
31 Available
$89.00/ 1pcs+
If you're new to the world of hardware, don't panic—the Maker Kit has everything you need to level up from hacker zero to hardware hero.  In addition to a shiny new Photon, the Particle Maker Kit includes all the components and accessories you need to start building simple Internet-enabled projects.
The Maker Kit comes with enough jumper wires, LEDs, resistors and more to make sure you can can build multiple different types of projects. It also comes with a super-neat project carrying case so you can put tidy up your workspace when you're done building.
All Particle Hardware is designed from the ground up to work with the Device Cloud.The Device Cloud is a powerful set of tools and infrastructure to build, connect, and manage your IoT fleet.
Access to the Device Cloud includes:
Device Cloud FREE for first 100 devices (learn more)
Device Cloud Features:
  • Device Management
  • Over the Air Firmware Updates
  • Fully Managed Connectivity
  • Developer Tools
  • Integrations
Technical Details
Dimensions181mm x 122mm x 46mm
WeightG.W 416g
BatteryExclude
Photon with Headers 1
USB Micro B Cable 1
Flex antenna 1
Mini Breadboard 1
Proto-board 1
Deluxe Jumper Wire Pack 1
Male to Female Jumper Wires10
Battery holder - 4xAA 1
Headers7
Ceramic Capacitors10
Electrolytic Capacitor 100uF5
LEDs10
RGB LED 1
Diode6
IR LED 1
Resistors30
Photoresistors 2
10K Rotary Potentiometer 1
Temperature Sensor 1
Temperature Sensor - Sealed 1
Piezo Buzzer1
Mini Pushbuttons3
SPDT Switch 2
SPDT Relay 1
NPN Transistor 1
PIR sensor 1
Pancake Vibration Motor 1
Micro Servo 1
Serial OLED Screen,0.96"1
ECCN5A991.b
HSCODE9023009000
Reviews
Questions and Answers
SUBMIT
    View History
    SKU 110060705
    $89.00
    31 Available
    $89.00/ 1pcs+
    • Related
    • Description
    • Technical Details
    • Learn
    • Reviews
    • Questions and Answers
    SUBMIT
