the AI Hardware Partner
Toggle Nav
Loading...
Pibow Rainbow Enclosure for Raspberry Pi Model B+
The all-new Pibow for the Raspberry Pi Model B+ redesigned with add-on boards in mind
$18.50
Out of stock
  • 10+: $16.65
The all-new Pibow for the Raspberry Pi Model B+ redesigned with add-on boards in mind. The Model B+ Rainbow is a sleek, durable and attractive case crafted out of eight unique layers with a transparent top and base that leave your beautiful Pi visible inside. Each layer is laser-cut from colorful high-quality cast acrylic (or spruce in the case of the Timber) and once stacked they securely contain a Raspberry Pi Model B+ while leaving the primary ports, including the camera port, accessible.
FEATURES
Extra extension layer included
Many add-on boards can now fit inside!
Icons and cut outs moved to leave the lid clear
Weighing only 92 grams the case is lightweight and ideal for mounting to any surface. No tools are required for assembly or disassembly.
SPECIFICATION
Now includes a free extension layer
Clear top and base to leave Raspberry Pi visible
Etched port markings and cable escapes
Leaves primary ports accessible
Lightweight high-quality layers
Protects your Raspberry Pi
DOCUMENTS
If you need any technical support, please visit Pimoroni forums.
Dimensions 0mm x0mm x0mm
Weight G.W 114g
Battery Exclude
HSCODE 3923100090
ROHS 1
